68 Radiator Shroud Seals
Those of you that have restored your radiator shroud, I am looking for guidance on installing the rubber seals.
I have removed the old seal and my question is when installing the new replacement seals, how did you attach it to the metal shroud. The original was stapled on. Did you reinstall with staples and if so how, what tool was needed? Or did you use adhesive?
Open to any and all suggestions.
Thanks in advance,
Peter
Thanks in advance,
Peter
Received 2,878 Likes
Hi Peter,
The various venders sell preformed staples for use in attaching the rubber seal to the perimeter of the fan shroud.
It's easiest to use the same holes in the shroud that the original staples made. (A pretty serious stapler must have been used originally to shoot the staples through the steel!)
I used a needle to locate each hole in the seal, and make the hole, and then a pliers to push the staple through the seal and shroud.
I then used 2 small needle nose pliers to bend the legs of the staples over to secure the seal in place.
A little tedious to do but not a bad job!
Regards,
Alan
Regards,
Alan
twinpack (11-15-2016)
