I just rebuilt the calipers and replaced the master cylinder on my 77. I'm working on bleeding the system with a vacuum bleeder. I cant get the Pistons to stay in? I can push them in but they won't stay. Is this because I still have air in the line? I thought it would improve as I got more air out of the line but it hasn't. May be a dumb question but any insight would be great.
The calipers are installed, the pads are tight to the rotors and won't retract unless I move them manually. When I push the brake pedal they engage but don't retract. I've never done this and they were in pretty rough shape when I took them apart, is why I'm concerned. They do have the stainless sleeves though.
They won't 'retract'. They normally are in very light contact with the rotor. The light springs behind the pistons hold them there. Are they ALL tight to the rotor? If it's just one I'd say the rubber line on that caliper is collapsed internally but if it's all of them I don't think it likely all the rubber lines are bad.
I'll have to take another look at it. I replaced all the rubber hoses also. The fronts have a small gap and when the brake pedal is engaged they compress. I'll work through finishing bleeding the lines and see if anything changes. Its my first stab at this so I was questioning whether or not I had the seals on the pistons correctly.
All Gm discs "dragged" on the rotors (1/60 of a horsepower). If your front pads are not contacting the rotors, something is amiss. What do you mean "the hoses compress"? The hoses will only collapse if there is a blockage in the system that is preventing the flow of brake fluid into the pistons when the pedal is released.
What type of seal did you put in there? Was it an "O" ring type or the original style lip seal ? AND most importantly did you follow any written instructions or diagrams on how to do it..
Corvette calipers have springs behind the pistons pushingles out - you saw them when you rebuilt the calipers, right? And did you have the tool to install the seals? Otherwise you probably tore them
