4 speed into an Auto Frame
Old Nov 20, 2016 | 11:49 AM
72 Project's Avatar
72 Project
Default 4 speed into an Auto Frame
Is this a direct bolt in or is some kind of adapter needed?
I have a 72 auto frame and a 73 manual frame. I plan on using the 454, 4 peed, and rear end components including sway bar from the 73 for doing a frame off on my 72 convertible.
Jim
Old Nov 20, 2016 | 12:06 PM
fishslayer143's Avatar
fishslayer143
a manual trans into an automatic frame is not an issue.. the automatic frame has removable X-member ..when you go the other way around it becomes a problem with the welded in X-member
Old Nov 20, 2016 | 12:22 PM
Alan 71's Avatar
Alan 71
Hi Jim,
Some folks doing the 4-speed/automatic change find locating the exact position for the clutch z-bar bracket to be a challenge.
So be careful to measure well before you remove the bracket from the 73 frame to weld it to the 72 frame.
Good Luck!
Regards,
Alan
Old Nov 20, 2016 | 01:48 PM
jnb5101's Avatar
jnb5101
My 70 was an auto frame with the removable xmember and the Z bar bracket.
Old Nov 20, 2016 | 06:19 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I put an auto frame under my '69 years ago when I converted to a C4 suspension. I just fabricated a replacement Z-bar bracket and welded it in the same location as on the original frame. One of the easiest issues in the frame swap.
Old Nov 20, 2016 | 06:50 PM
jimkari's Avatar
jimkari
I recently did an auto to manual swap in my '73. You will need to weld some tabs on the cross member to support the bracket that moves the trans mount closer to the front, but overall it's not bad and having the removable cross member from the automatic frame is nice if you need to removed the trans in the future.
Good luck, send me a PM if you have any questions. Not an expert, but have gone through the conversion.
Jim
Old Nov 20, 2016 | 09:06 PM
72 Project's Avatar
72 Project
Are there any pictures, diagrams or instructions for the changes to the crossmember?
Old Nov 20, 2016 | 11:15 PM
jimkari's Avatar
jimkari
The cross member mod is actually pretty straight forward. You will need to purchase a bracket that extends the trans mount forward. One end of the bracket bolts to the cross member in the same spot as the auto mount. The other end of the bracket moves the mount forward for the 4 speed. You will also need to purchase two tabs that weld onto the front side of the cross member and then the bracket is supported by these brackets. When I did my conversion. I bolted the bracket to the cross member and trans to locate the tabs and then tack welded them in place. I removed the new bracket and finish welding the tabs to the cross member. I think you can get the bracket and tabs at most of the main Corvette supply shops.
To 4 speed into an Auto Frame
