differential mount
Old Nov 21, 2016 | 03:03 PM
Staylor63's Avatar
Staylor63
Default differential mount
Hello Great Minds!
Here is a simple question before i get into this update...I need to change my rubber diffy mount. Can i do this without removing the driveshaft, or is the bolt too long to remove without doing so?
...Oh yeah, it is for a 1980 4 speed i just picked up.
Thanks in advance!!
Steve
Old Nov 21, 2016 | 03:51 PM
MelWff's Avatar
MelWff
I changed it on a 69 without removing the driveshaft
Old Nov 21, 2016 | 04:20 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I changed my '76 by unbolting the rear straps and moving the drive shaft a few inches to the left.,
Old Nov 21, 2016 | 06:13 PM
lvmyvt76's Avatar
lvmyvt76
I did too, have a mount that I would sell, just PM me.
Old Nov 22, 2016 | 03:43 PM
Staylor63's Avatar
Staylor63
Thanks for the offer...i wish i saw it earlier, already placed an order with Ecklers.
Old Nov 22, 2016 | 05:02 PM
Mark Riles's Avatar
Mark Riles
Originally Posted by Staylor63
Hello Great Minds!
Thanks in advance!!
Steve
When was the last time the joints were checked and / or replaced? It might not be a bad idea to check them. They do wear and run dry and when you are down there, it's fairly easy to pull the drive shaft and check everything.
Old Dec 3, 2016 | 11:48 PM
SciVette's Avatar
SciVette
It can be done, but it's a PIA... My biggest problem was trying to leverage down the tongue of the batwing/diff to remove the rubber bushing sandwiched between the tongue and frame piece- without crushing the brake line that runs right where you need to put the crowbar...
Old Dec 4, 2016 | 08:45 AM
Staylor63's Avatar
Staylor63
Thanks to all....I ended up just pulling the driveshaft. With the right tools (1/4 12 point socket) it was pretty easy.
To differential mount
