LT-1 mis-firing
down. Has been in long term storage but gas was always treated. Holly carb was sent out and reconditioned- appeared clean. New plugs, old ones dry when they came out. Any LT-1 motor heads ot there with ideas? Previous owner(s) have documented a lot of ignition issues in the past, I've only had the car 2 years so not real experienced.
Did you check the condition of the cap and rotor?
Did you do a resistance test on the plug wires, 1k/ft.
What make and number spark plug did you install?
Did you gap the plugs to .035?
Did you adjust the idle mixture screws when you installed the carburetor?
http://www.tispecialty.com/articles/article1.htm
Great stuff - thanks! I'll go through the checks and let you know.
