1969 lock cylinder linkage problem?
Thanks for listening. This is a great Forum and I'm glad I went for the Lifetime membership.
John
I don't have an answer to your steering column link question but it seems you may be describing 2 situations.
Getting the transmission out of reverse does have to do with the interlock lever on the column and the cable running to the reverse lever on the transmission. Remember although the reverse lockout affects the ignition switch it's the shifter that controls the lever and cable.
The 'no start' situation has to do with the clutch interlock switch which is mounted on the clutch pedal arm under the dash. Is the switch hooked up and are you depressing the clutch to start the engine?
Regards,
Alan
The cable end at the reverse lever on the transmission.
The gear in the picture below is turned by the lock cylinder which rolls the gears and makes the rod move. So.. if you reach under the column by the ignition switch you'll find the end of this rod... see if it moves when you turn the lock cylinder.
If the interlock cable is stuck, you can disconnect it from the steering column and wire the column lever in place for a temporary "bubba" fix. This would allow your column to work in any gear or position as long as you move the lever to the correct position.
Regards,
Alan
