Ack! I'm going crazy doing research!
Old Dec 1, 2016 | 05:35 PM
mpro71vette's Avatar
mpro71vette
Default Ack! I'm going crazy doing research!
I'm trying to figure out If I should go sharkbite rear and front or VBP performance plus suspension. I read everything about each. I have a 1971 and I don't plan on racing, only street driving. I want a nice ride maybe on the soft side. What say everyone?
Old Dec 1, 2016 | 06:15 PM
Domobomb's Avatar
Domobomb
Refurbish stock suspension. Maybe use composite leaf spring in the rear.
Old Dec 1, 2016 | 08:37 PM
sunflower 1972's Avatar
sunflower 1972
Old Dec 1, 2016 | 08:44 PM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
Give Van Steel a call and talk to Paul or Dan,
These guys are straight shooters, and will steer you right.
Old Dec 1, 2016 | 09:17 PM
mpro71vette
I really like Van Steel, but there a little heavy on the pocket. By the time its done it could be over $4000. If I buy just the springs on the vbp plus its only $1800, on the sharkbite will cost around $2500. I'm leaning toward the VBP plus, there is hardly any negative comments on them. On the sharbite, I read the possibility of it breaking, although slim, on the back and front, but dang they look good!
Old Dec 1, 2016 | 09:29 PM
Domobomb's Avatar
Domobomb
He didn't say go buy Van Steel full coil over kit. Van Steel can get your stock suspension working great in short order and they sell composite leaf springs too.
If you're dead set on spending a bunch of money, I think the VBP kit is better than the sharkbite kit for what it's worth.
I bought the VBP full performance plus kit and I'm installing now, but I'll be doing a little more than just cruising the street.
VBP customer service is very bad so be aware.
Old Dec 1, 2016 | 09:35 PM
mpro71vette
Thanks Domobomb! I'll give van steel another look but I think I'm gonna go with the VBP,
Old Dec 1, 2016 | 11:31 PM
Crimson Thunder's Avatar
Crimson Thunder
I'm going to do VanSteel coil overs. You can save on shipping and drive two hours and pick them up.( same with VBP)
Old Dec 2, 2016 | 03:52 PM
ENCSDOUG's Avatar
ENCSDOUG
I went with Van Steel front and back with tubular A-arms and coilovers with double adjusting shocks. No leaf spring. She rides very nice.
redman76's Avatar
redman76
St. Jude Donor '09
VanSteel sells the VBP stuff. I bought the Street and Slalom suspension from Dan at VS and was very pleased with the recommendations and results.
Old Dec 2, 2016 | 05:16 PM
Richard Daugird's Avatar
Richard Daugird
Save your money, do this first. If you aren't happy, you can upgrade later. Rememeber, these things were sports cars from the get go, if you are not racing, you don't need that exotic stuff.
Old Dec 2, 2016 | 10:10 PM
lvmyvt76's Avatar
lvmyvt76
this what I did: composite spring, good shocks, everything else stock, front: new springs, good shocks, and everything else stock rubber. rides great. added bigger front sway bar and added rear sway bar.
Old Dec 3, 2016 | 12:18 PM
Big2Bird's Avatar
Big2Bird
I think the Sharkbite is trash.
Old Dec 3, 2016 | 03:23 PM
ignatz's Avatar
ignatz
While I tend to agree with your sentiment, I wouldn't go so far as to call it "trash". Want to elaborate?
As far as what I think, it looks kind of silly on display back there but that is just a matter of my opinion. Nobody cares about that. Not to mention having to keep it all clean and shiny. What does the Sharkbite technically provide over and above spring rate and damping? If it is just adjustability, that is a lot of money and effort spent.
Basically the suspension is a passive second order system with a restoring spring force and damping. Why do Sharkbite owners praise it when spring rate and damping are the essential functions and why would Sharkbite be any better? Just saying it feels great is not very illuminating. By what objective measure might it be better? Has it ever been put to the test somewhere with any kind of external stimulus? I have the feeling this has been discussed many times before and it's come to nought, but I'll ask the questions.
To Ack! I'm going crazy doing research!
