L46 Valve stem diameter for seals
Old Dec 5, 2016 | 05:49 PM
35035069c3's Avatar
35035069c3
Cruising
Default L46 Valve stem diameter for seals
I've read quite a few posts regarding valve stem seals, and there are plenty of them. I have the common smoke issue on deceleration and want to try the seals since it's fairly simple. I'm having difficulty finding the diameter of the valves to match with the parts to order. I have a GM seal kit 1#12511890, with the following info on the bag, 7488K3, GR. 0.308, and would like to know if they would work.
C3 info 1969, L46, 4spd. 2.02/1.60 Heads 11:1 compression
Thanks in advance, and let me know if you need more info.
Old Dec 5, 2016 | 06:26 PM
DUB's Avatar
DUB
These valve seals should be just like regular rubber round 'O' rings. I have not seen the hard plastic umbrella cups that would go the valve stems for your year model....nor any of the current designs of umbrella seals. The heads were not machined for them to lock into place.
I know some people put them in anyway.
DUB
