composite rear spring question
Old Dec 15, 2016 | 08:31 PM
Kacyc3's Avatar
Kacyc3
Default composite rear spring question
I am trying to install lowering bolts int he rear of my car and I noticed the spring bolts are angled from the trailing arm backwards to reach the hole in the spring. This isnt correct right?The bolt should drop straight down from the TA to spring holes right?
Old Dec 15, 2016 | 09:35 PM
'75's Avatar
'75
When the trailing arm is at ride height, the holes align much better.
Old Dec 16, 2016 | 04:57 AM
kanvasman's Avatar
kanvasman
Ditto above. Jack under the trailing arm to lift it up and it should work OK.
Old Dec 16, 2016 | 03:01 PM
Dodosmike's Avatar
Dodosmike
Following along.
I want to R&R with longer bolts. Hoping I can just jack up the arm, pull the bolt and drop the replacement right in, run up the nut to the height I want and then get an alignment.
If the T/A is in the "driving" position (or close to it) and I jack the end of the spring to take the tension off the lower cushion should the bolt just pull up without binding (much)?
Old Dec 16, 2016 | 05:19 PM
'75's Avatar
'75
Yes it should slip right out. If you have a rear sway bar the mount will need to be removed because it mounts above the bolt head.
To composite rear spring question
