they are weld draglight wheels. They are 15" X 5". and i think the backspacing is 4.5" but i would have to double check that. Getting them on was not easy. I had to grind the calipers, change the wheel studs and use a big spacer then buy special expensive lug nuts. They handle ok and they took about 50 pounds off the front of the car. Combined with my 90/10 front shocks you could say my car is not able to turn for, well you know. :D Now if i could just get a pair to match the back :) That will happen next year i suppose :chevy
Sounds like too much work to me... I will need 5 inch backspacing for wheels to fit with no mods - right??
the expensive one might work. but you might still have to change the studs :crazy: i dont know, but i havent done the rears yet cause i had enough of that bs for one year :jester
I wonder why it is so difficult to find the right rims for C3's... :confused:
