Hole in transmission?
Pete
flow around the pan and into the bell housing, which then looks like the front seal is leaking.
I would remove the bell housing and then use brake cleaner to clean the transmission and pan. Start the car, check that the transmission is filled and look under the transmission for the source of the leak.
I would start with replacing the pan gasket. And straightening the pan or replacing the pan before installing the new pan gasket.
