Muncie 4 speed 1st / 2nd gear rod question
I believe this is the one that has the pin that attaches the lever to the arm via a pin. Does anyone sell just the pin or know of a substitute? I have everything else for the shifter, but can't find the specs for the pin. I really don't want to buy the replacement arms just for that part.
Good luck buying just one though.
Not sure what you mean. Is it the clip that attaches the trans shift lever to the shifter rod? I so it's called a G-clip.
http://www.parts123.com/corvettecent...50g&ukey=11468
It's the part the g clip goes into. I found one on eBay and ordered it. Trying to avoid doing bubba work, other wise it like would have something in that likely would work, but not right.
