200R4 - Is Lock up required
Old Dec 27, 2016 | 11:26 AM
Tater 1's Avatar
Tater 1
Default 200R4 - Is Lock up required
Crunched the Turbo 350 Tranny in my 1980 Vette.
Found a 200r4 from a 85 Caddy to swap out.
i Have a guy who is willing to rebuild it.
He said we can use regular parts, add a shift kit and we are good to go.
My engine is a 350 with 265HP to the rear wheels (about 350hp at fly).
3.55 rear end gears.
He also said that we can skip using the "Lock Up" system.
So, two main questions. Besides the shift kit are there any upgrades that should be made to this transmission when rebuilt?
What are any major problems one would encounter by not using the lock up on the torque converter.
Thank you for any help,
Old Dec 27, 2016 | 11:44 AM
Big2Bird's Avatar
Big2Bird
I would install this kit:
http://www.transgo.com/products.php?...dcountview=Yes
And this kit for hydraulic lock up:
http://www.transgo.com/products.php?...7&prod_start=2
With these, there are NO problems with using LU torque converters.
Old Dec 27, 2016 | 12:58 PM
NewbVetteGuy's Avatar
NewbVetteGuy
I thought the 1980s came with lockup TCs and the lockup switch already on the brake pedal, no?
If you don't use a lockup torque converter you'll want a separate trans cooler mounted in front of the radiator for cooling. The Torque Converter will help keep the trans cool (which means live longer) and it will also improve highway cruise fuel economy.
Adam
Old Dec 27, 2016 | 01:17 PM
Big2Bird's Avatar
Big2Bird
When I first installed the 700R, we went on a road trip in the mountains. I pushed it quite hard. Blew 3 qts out from overheating. When we returned, I installed a cooler in front. Had the tranny checked, no damage.
Next trip, fluid never got hot, just warm.
Old Dec 27, 2016 | 01:21 PM
Big2Bird's Avatar
Big2Bird
Old Dec 27, 2016 | 01:29 PM
76strokervette's Avatar
76strokervette
Lockup is not required with a few mods. Most that go without lockup are making big power which would require a multi disk lock up converter.
The multi disk converters are quite expensive.My set up is a Vince Janis 2004r with billet input shaft and drum with a PTC non lock up converter.
I will also be running a 12 bolt 4.11 rear. IMOP your set up will work just fine with the lock up. I would stay local with the rebuild just in case there is an issue to avoid shipping hassles etc... The wiring kits are readily available and should not be a deterrent. The turbo buick site has a wealth of information for this transmission and I would advise you to check there.
Old Dec 27, 2016 | 01:37 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I agree with all of the above. I like the hydraulic lock up kit. Very simple to install. All you need is switched 12 volts and a ground and it'll figure the rest out for itself.
Also, do yourself a favor and add an external cooler for the transmission. It'll extend the transmission life and keep your engine cooler for good measure. I added a thermostatically controlled bypass to allow it to warm up on cold days.
Having said all of the above, not having the lock up enabled will cost you a little more heat generation in both the engine and transmission from higher revs and a little extra gas. Not a big deal.
mrvette's Avatar
mrvette
I don't pull mountains, but make up for it with FLORIDA heat, and sunshine melting the assfault on the roads...suffice to say I put an engine oil cooler between the HVAC cond. and the rad....it's about a foot square and near 2" thick, and so I run the ATF from the 200 4r through it, and I make a mad dash over the bridge in 100f+ daze at 80+ then into bumper/bumper traffic without a stitch of airflow except the Dual Spal fans....and the trans pan temps are only 130f.....believe it or not......
wish I could run it at 30f like a cold winter start...it shifts like a running bandit then......
Old Dec 27, 2016 | 04:24 PM
SH-60B's Avatar
SH-60B
He's right, you can skip lockup, you'll only sacrifice a little fuel milage. I didn't skip the lockup, but I did put in an auxilliary cooler, plumbed in after the radiator cooler. I also put in a transmission temperature sender in the pan. Fluid temperature only got as warm as the engine coolant twice (190), after trips of well over an hour. It generally ran 120 to 130 degrees.
Old Dec 27, 2016 | 05:49 PM
John 65's Avatar
John 65
Sorry, don't mean to hijack the thread, but a quick question.
Will an external cooler alone work? My legs are bothering me now and I am considering going back to auto. Radiator is for a manual. Its a BB with around 400 hp and 3.70 rear. Picked up a 200 and various parts for the swap but not sure about cooling. Thank you.
Old Dec 27, 2016 | 06:21 PM
76strokervette
You can buy a cooler with a thermostatically controlled fan that will probably work.Those are popular with the snow plow operators and work quite well.
Hope this helps,
Dave
Old Dec 27, 2016 | 07:30 PM
mrvette's Avatar
mrvette
Try my engine oil cooler trick mentioned above.....it has to be over twice the cooling of the largest ATF cooler I ever seen, and it's plumbed alone nothing in the rad tank....don't see the need.....now if you live in the lands of -0f winters....well maybe put the rad in the circuit...maybe....
Old Dec 27, 2016 | 08:04 PM
gkull's Avatar
gkull
The 200r4 is weaker that a th350. Shift kits andTransgo valve body kits don't strengthen the tranny. Without serous internal hot rodding it is not going to last behind your power
Efficient 9.5 inch even 3500 rpm stall produce little heat or lower mpg over their lockup counter parts
Vigilante tc and external big coolers.
Old Dec 27, 2016 | 08:48 PM
johnt365's Avatar
johnt365
Check out this write up on the turbo buick site.
http://turbobuick.com/threads/attent...e-2004r.31365/
My car has about the same power as yours and same gears too. I bought a used 2004r out of a 87 Monte Carlo SS. The guy said he could not get second to shift how he wanted. I put it in and just cruising around town and to the grocery store it would have been just fine. But, punch it and it would slip at the shift points.
I made two upgrades:
1. CK Performance shift recalibration kit with .555 boost valve
2. CK Performance pro street servo
The increase in pressure and calibration fixed the sloppy shifts and has prolonged the life of the unit.
Why don't you want OD? Seems like heat would be the biggest side effect of no OD.
John
Old Dec 27, 2016 | 09:13 PM
TimAT's Avatar
TimAT
Make sure the bellhousing bolt pattern is the same as the Chevrolet. Lot's of years there were 2 distinct cases- one for Chevrolet and a BOP that also covered the Cadillac. There are even some that fit everything.
Old Dec 28, 2016 | 02:24 AM
7T1vette's Avatar
7T1vette
The 200-4R from a Cadillac may already have most of the upgrades built into it. But, that needs to be researched; the primary upgrades may not have been available in '85.
Also, make sure the total length of that trans is correct for your car. There were different length tailshafts on some builds. If it is longer than the unit you have in there now, you might have installation problems.
No you don't HAVE to install or hookup the lockup clutch. But, the transmission will run significantly hotter when cruising at speed, if L/U is defeated. You will also lose about 5 to 10% fuel mileage if you don't take advantage of the L/U feature.
Old Dec 28, 2016 | 07:02 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
I opted for a non lockup build, no issues
Neal
Old Dec 28, 2016 | 08:58 PM
John 65's Avatar
John 65
Thank you guys for the reply's, will have to look into it.
Old Feb 20, 2017 | 11:29 AM
Carl in LA's Avatar
Carl in LA
Years ago I purchased a 2004R from Bowtie Overdrives...
At the time they offered a manual switch to lock the transmission (apparently in 4th Gear???)
http://www.bowtieoverdrives.com/cata...php?ITEMID=340
Now they offer a more sophisticated lockup that links to the brake pedal to presumably unlock itself...
http://www.bowtieoverdrives.com/cata...php?ITEMID=339
With the manual switch - I can report that for my type of driving I have only locked the transmission perhaps twice... once 16-years ago to see the effect was like - which I did not like... and once a couple years ago to see "hummm - what does that switch do?" - and then I remembered why I had not used the switch for 14 years...
Perhaps better with the brake relay to unlock upon braking but I did not like lugging down the engine decelerating from highway speeds pending turning off the switch.
Also - the 4-speed overdrive transmission is the single most valuable mod made to the car...
To 200R4 - Is Lock up required
