Changing Tire Size...effects? if any?
Old Dec 27, 2016 | 11:24 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Changing Tire Size...effects? if any?
I've changed all 4 tires from a BFGoodrich 225R70x15 tire to a BFGoodrich 235R60x15. What will this affect (other than ride height)?
Old Dec 27, 2016 | 11:30 PM
'75's Avatar
'75
Your speedo will be off some also.
Old Dec 27, 2016 | 11:46 PM
vetteguy75's Avatar
vetteguy75
Yep...I checked the speedo against my GPS on the interstate and is was 10mph difference (speedo=60mph...actual=70mph)
Old Dec 27, 2016 | 11:50 PM
'75's Avatar
'75
Seems like it would be off the other way running shorter tires. Those are almost 1 1/2" shorter.
Old Dec 28, 2016 | 02:53 AM
Antz81's Avatar
Antz81
I agree. Might bee a good idea for the OP to check his speedo gears.
Old Dec 28, 2016 | 03:06 AM
WESCH's Avatar
WESCH
Hi
I don't believe that you will feel a difference by changing the same tire brand from 225 to 235 size.
Changing from 225 to 255 can be felt , specially on the front and this in different ways. Or changing tire brands can sometimes be felt.
Why didn't you go 255 in the back ?
Rgds Günther
Old Dec 28, 2016 | 05:35 AM
vetteguy75's Avatar
vetteguy75
Originally Posted by WESCH
Hi
Rgds Günther
Because I wanted to be able to rotate the tires.
Old Dec 28, 2016 | 05:43 AM
vetteguy75's Avatar
vetteguy75
Yeah...you're right. But that's what I am showing right now. I'll check again. If it shows like I said...what would cause that? (speedo=60, actual=70)
Old Dec 28, 2016 | 07:08 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I did that. Its 77-78 reading at 70, not quite 10 mph at 70. Its around an 7-8 % across the board. I was going to change the gears in the box, just havent got around to it yet. I cant remember which way to go, I thnk I need a larger gear to slow it down
Old Dec 28, 2016 | 08:48 AM
vetteguy75's Avatar
vetteguy75
Is that difficult to do?
Old Dec 28, 2016 | 08:49 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Compared to the OEM tire size (which your transmission was originally calibrated to) Your new tires should yield an actual/GPS speed of 57.8 mph when the speedometer reads 60 mph. Looks like your speedometer needs calibration OR your drive gear needs changing.
Old Dec 28, 2016 | 09:28 AM
Rescue Rogers
Its the driven gear.
http://www.camaros.net/forums/27-tra...placement.html
Old Dec 28, 2016 | 09:32 AM
Rescue Rogers
Yet another thing I need to do this sprng
Old Dec 28, 2016 | 09:37 AM
Rescue Rogers
Youll need to take yours out so you know which way to go
http://www.ecklerscorvette.com/trans...d-sensors.html
Old Dec 28, 2016 | 11:57 AM
Bally's Avatar
Bally
235/60's are too small on a C3, especially in the rear, doesn't fill in the wheel wells as it should.
Sorry, I know you already bought them, but I am on a bit of a crusade, as I keep seeing these little tires on Vettes. The diameter is too small! Spot them at a shows from 500 feet away all the time.
The devil is in the details and a 1" diameter shrink from the stock diameter doesn't make it.
245/60 minimum (still a tad too small IMO), 255/60 ideal, especially in the rear.
225/70/15 tires look ideal on a C3.
Better yet, Coker just released a Wide-Oval Radial (also red lines). This is big news! Exactly what the original designers of the C3 chose, knowing the wheel wells needed filling for the best look with that body.
This guy explains it better than I am:
Sorry again!
Old Dec 28, 2016 | 12:09 PM
Antz81's Avatar
Antz81
10 mins to do the change. Plus working out what gear you need. You'll need a smaller gear than what you have. Not sure how much smaller without knowing whats in there already
Old Dec 28, 2016 | 12:34 PM
OldCarBum's Avatar
OldCarBum
I'm running BFG T/A 245-60-R15's front and rear. They ride good and I like the fact that I can rotate them front to rear. When I turn my front wheels to the fully locked position, my tires just kiss the inside wheel well. You may not have that issue with the 235's.
To Changing Tire Size...effects? if any?
Old Dec 28, 2016 | 04:10 PM
WESCH's Avatar
WESCH
Hi
For show and shine ok; but for driving with the max speed rating at only 180 kmh not even legal over here in Europe.
With a better speed index , this tire would be nice.
Rgds Günther
Old Dec 28, 2016 | 06:00 PM
Peterbuilt's Avatar
Peterbuilt
[QUOTE=vetteguy75;1593745273]I've changed all 4 tires from a BFGoodrich 225R70x15 tire to a BFGoodrich 235R60x15. What will this affect (other than ride height)?
Here's a calculator:
http://www.discounttiredirect.com/di...nfoTireMath.do
Old Dec 28, 2016 | 06:03 PM
Bally's Avatar
Bally
Hi
Rgds Günther
Right, so 225/70/15's then.
Otherwise:
255/60/15 rear, front if they don't rub.
If they rub:
245/60/15 front
Any smaller, too much negative space in wheel wells.
BFG's wear very well, rotation isn't a big issue unless lots and lots of miles driven.
235/60's have a stiffer sidewall, so the car will handle better than 225/70's, just won't look optimal doing it!
I'm trying to get the OP to at least get 255's on the rear! His 235's will sell fast on Craigslist!
(sorry...)
