Holley Stealth Ram ECM issues
Old Dec 28, 2016 | 05:48 PM
Japery's Avatar
Japery
Default Holley Stealth Ram ECM issues
I bought someones project 77 with a Holley Stealth Ram a couple years ago and have some issues with the ecm[ecu,pcm]. It has a 1992 Iroc 350 ecm and was wondering if I get it updated will it make any difference in hp? I now have a 355 400hp crate with side pipes. Anyone else out there have fuel pressure regulator problems with this set up and any thoughts on this TPI swap? Iv tried searching this subject but cant find the answer im looking for.
Old Dec 30, 2016 | 08:39 AM
tektrans's Avatar
tektrans
You have the Holley system in conjunction with the 92 Iroc pcm correct?
Outta my league-that's why I have a carb. lol
Old Dec 30, 2016 | 02:05 PM
Kacyc3's Avatar
Kacyc3
If i understand this correctly you are using the HSR intake only and the 92 ECM correct? Are you using a vacuum adjusted regulator or spring adjusted?
Old Dec 30, 2016 | 03:14 PM
zwede's Avatar
zwede
If you're running the factory 92 TPI calibration on the ECU then yes, I can see why it wouldn't run well. Either find someone who knows how to tune these old ECUs or switch to a newer ECU like the Holley HP.
Old Dec 30, 2016 | 04:00 PM
Japery's Avatar
Japery
Im not really sure what type of fuel regulator holley uses on these but iv heard from the grape vine that there not very good and need to be replaced by an after market part.
Old Dec 30, 2016 | 04:06 PM
Japery's Avatar
Japery
WOW. I just looked up the price of the Holley HP. $1600 for the ecm and harnes is out of my price range. Looks like im looking for someone to reprogram the ecm.
Old Dec 30, 2016 | 04:17 PM
Kacyc3's Avatar
Kacyc3
do you have the patients and desire to learn to tune that factory ecm?
Old Dec 30, 2016 | 04:30 PM
Japery's Avatar
Japery
Im very confused on these pcms. If I wanted to update my gauges or have more codes should a just reprogram a newer OBDII from a newer car? I believe a 92 is OBDI. Id like to remod this car and wonder what my options are.
Old Dec 30, 2016 | 04:32 PM
Japery's Avatar
Japery
I would but I heard that the software is more than having someone do for me. Is this fact?
Old Dec 30, 2016 | 04:43 PM
lionelhutz's Avatar
lionelhutz
Software is free but you need a couple $100 worth of hardware to do it.
Old Dec 30, 2016 | 05:36 PM
Kacyc3's Avatar
Kacyc3
your options are
tune existing ecm - $100 plus cost of chips - slow and irritating
switch to obdII - cost of ecm and wiring harness, cost of software or pay someone to do it if you can find them. Most OBII systems use a crank trigger of some sort.
aftermarket efi - expensive up front but you get the software to tune your car. if you look around you can find older efi setups for a reasonable price.
Old Dec 30, 2016 | 07:57 PM
lionelhutz's Avatar
lionelhutz
I almost forgot, but you could do a dynamicefi.com conversion on the ECM and then you can tune it almost like a newer PCM. Cost is maybe around $400 or so.
You can tune the existing ECM with an emulator and get real-time response to any adjustments. It works even faster than using a OBDII PCM.
Old Dec 30, 2016 | 08:12 PM
Japery's Avatar
Japery
You have my attention! What would I google to learn more on this emulator?
Old Dec 30, 2016 | 08:13 PM
Japery's Avatar
Japery
Sorry I found it
Old Dec 30, 2016 | 10:13 PM
Kacyc3's Avatar
Kacyc3
Sorry I found it
check out gearhead-efi.com , reading their site has helped me learn alot about the ecm in my 87 truck.
To Holley Stealth Ram ECM issues
