Effects of Dwell on Timing - Points Distributors
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
The C1/C2 Forum got into a lengthy 9-page discussion on this subject matter. You can read the whole thing here:
https://www.corvetteforum.com/forums...post1593766803
But if you just want a summary of the factual findings of the relationship between Dwell and Timing, I summarized it after some testing in post #175:
So here is the final summary of everything discussed and determined. I just fired up the test engine this morning and took some last measurements and made some observations:
Set up and ready to fire it up with dwell meter and feeler gauges:
Dwell meter verified calibrated at 45 degrees with engine not running:
Engine running. I like to run a little more than 30 dwell on my own engines, but I backed off this 31.5 reading to 31 degrees for the meaurements to be taken:
I can't remember the last time I actually checked point gap with a feeler gauge, but I did it this morning:
Final Results and Summary:
- You can make minor timing adjustments using the dwell adjustment screw.
- 1 degree change in dwell changes timing 1 degree.
- Turning the screw IN (clockwise) INCREASES dwell and DECREASES timing.
- Turning the screw OUT (counter-clockwise) DECREASES dwell and INCREASES timing.
- Turning the screw 1/8 turn changes dwell and timing by about 3 degrees.
- .019" point gap = about 31 degrees dwell.
- Increasing point gap decreases dwell and increases timing, and vice-versa.
- A 2 degree change in dwell changes point gap by .003", so every .0015" change in gap changes dwell and timing by 1 degree.
Lars, right to the POINTas always. Your TIMINGis perfect. No DWELLINGon the subject, just a CONDENSEDversion CAPPEDso as to notIGNITEnor INDUCEfurther arguements.
mrvette (01-01-2017)
haha....I still have a dwell meter somewhere.
I'm so glad not to do that anymore...
Lars
thanks for the summary. I started following the C1/C2 thread on the topic but eventually gave up on all the back and forth going on.
