C3 Ratchet Shifter mod
To operate it on a four speed automatic, just push the button down and move forward for the 1-2 shift. Release the button and move forward the 2-3 shift. Then push the button down again and move forward for the 3-4 shift.
To operate it on a three speed automatic, just push forward for the 1-2 shift. Then push the button down and move forward for the 2-3 shift.
I have been very busy lately, as caretaker of my elderly father. If anybody tries this before I get the chance to build mine, please show me yours and tell me how it works for you.
I am certain that this shifter mod will operate as designed to provide positive no-miss shifts. All without any modifications to your car or dash, and maintaining the stock look of the car. The used shifters sell on ebay for about 50-100 bucks, depending on condition. So with a little "sweat equity", cut and grind, and a spare piece of sheet metal you should have a gated stock shifter for 1/3 the price of a fancy aftermarket shifter that won't fit your dash without major work.
another issue i'm having is the total travel of the neutral safety switch. But a new switch might fix my issue; which is that the reverse lights are on in neutral instead of reverse. I'll see if i can pick up a switch in Carlisle in a few weeks.
What 4l80E shifter are you using now in your C3? Why do you need manual shifting in a 4l80E? Trans brake?
it ain't pretty, but it works during bench testing while connected to 700r4 transmission.
I used stainless steel flat stock (actually it was shelf brackets from a restaurant) that was .10 think; just under an 1/8 inch.
the next step is to mount in to stock shift, which I'll do with nylock nuts & bolts.
Can't wait to road test it. But the Ideas here are fantastic, so thank you again.
(Total cost, including dremel tools, drill bits, scroll saw blades, etc, about $30.)
Great ideas.....and here I was over-thinking it. I'm going to a 200-4R but the idea should work. Many thanks.
here's a slap shifter that looks like stock and not gaudy for 77-82. https://shiftworks.com/products/1977...40671122686125
