Clutch Freeplay????
Old Sep 20, 2002 | 03:18 PM
Corvettelvr73's Avatar
Corvettelvr73
Default Clutch Freeplay????
I just installed a new Center force Dual Friction in and I am at the end of the adjustment rod
but I still have about 3 inches of freeplay and it grabs very close to the floor. Is there a new
rod I can change it out with that may be a little longer? Part numbers or other ideas needed.
Old Sep 20, 2002 | 03:34 PM
Fevre's Avatar
Fevre
Default Re: Clutch Freeplay???? (Corvettelvr73)
I just happend to have a longer clutch rod running from the z-bar to the fork which took up the slack. They prevous owner must have intalled a similar clutch since there was a little tab welded on that rod which extended it. I bought a new rod but it is too short. You will also have a problem with the fork geometry if you did not get an adj pivot ball stud.
[Modified by Fevre, 1:34 PM 9/20/2002]
Old Sep 20, 2002 | 03:36 PM
73 LS-4's Avatar
73 LS-4
I think thats common with the dual frictions and their throw out bearing which tends to be shorter then stock, mines just about at the very end of the adjustment rod as well, but I like my engagement low personally.
:cheers:
Pat Kunz
Old Sep 20, 2002 | 03:44 PM
PRNDL's Avatar
PRNDL
Default Re: Clutch Freeplay???? (73 LS-4)
This problem comes up time and time again!! I have the same problem, and with the help of other forum members can pass on the following info:
The centerforce clutch comes with an orange sheet of paper that tells you to use an adjustable clutch for pivot ball stud with GM bellhousings. They also give you the measured distance you need to adjust the pivot ball. I just bought one last week, but I dont know when I might install it because I will have to pull the trans to get to it! :(
There are some bubba fixes that I havent tried yet and dont know how well they will work. 1.) You can try a longer clutch rod. This should allow your clutch to engage without putting the pedal to the floor, but if you do happen to put your pedal to the floor you may ram your clutch parts into other nonforgiving parts.
2.) Another forum member suggested to me it is possible to reach in and effectively shim the existing clutch fork pivot ball stud, creating the effect of a longer piovt ball. I havent tried this yet.
If you dont have the "orange sheet" I may have a copy that another forum member scanned and emailed to me. MJ
Old Sep 20, 2002 | 03:49 PM
Fevre's Avatar
Fevre
Default Re: Clutch Freeplay???? (MNJack)
2.) Another forum member suggested to me it is possible to reach in and effectively shim the existing clutch fork pivot ball stud, creating the effect of a longer piovt ball. I havent tried this yet. MJ
:D
The sheet metal shims worked great but wore through fast. The thin bar I am using now is too thick and am getting the binding again, not as bad as with no shim but still noticeable. Gonna try grinding the bar out a little to get the fork more perpendicular to the flywheel.
Old Sep 20, 2002 | 09:48 PM
GTR1999's Avatar
GTR1999
Mark,
I just bought a Center Force II clutch from Jegs. No Orange slip.The centerforce web site has a link to a tech page that says to use a adjustable pivot ball like you and others have said. The dimension is listed as 4.750" from the face of the flywheel to the face of the ball stud. Is that what your tech sheet says?
Also, as you said, this question comes up evcery time someone buys a CenterForce. Maybe it's easier to just get a stock one? :rolleyes:
Gary
To Clutch Freeplay????
