VB&P suspension kit
I'm looking to get a kit that can replace most of the current suspension systems and came across these 2:
VB&P GRAND TOURING PLUS SUSPENSION KIT
VB&P STREET & SLALOM SUSPENSION KIT
I want a street car, so I don't need to have the stiffest suspension ever.
What is your opinion on these kits? Did anyone try them?
I feel the Street&Slalom might be too harsh with 550lbs front coils, specially given that I might need to trim them a bit to lower the car.
Will I regret going with the softer Grand Touring?
Can you recommend some possibly better kits?
Thanks!
the 550 spring is one inch shorter in ride height. I had to space it up with a 3/8th inch spacer because of my low profile front tires.
I then found the rear to be lacking so I installed a 500+ pound rear spring.
I just got so used to driving it that any time I drove a lightly sprung Vette that I didn't even feel safe going around turns in them. I don't like driving them. I like solid with modern performance tires.
My 78 came from the factory with the gymkhana suspension. I made one change at a time over the past 30 years to improve the factory sport suspension and my car today, rides, handles, and steers MUCH better than it did from the factory. I have this suspension today:
Putting the factory gymkhana suspension on a 74 is easy (I would recommend the 78-82 F-41 settings):
front springs 550 lbs (base suspension is I believe 350lbs)
rear steel 7 leaf spring of 292 lbs (base suspension is 192lbs-9 leaf)
Front bar-1 1 /8 inch (base is 7/8 inch I believe)
Rear GM style Only sway bar 7/16 inch (no rear bar base suspension)
Bilstein HD's or Sports
A better gymkhana suspension like I have had for many years with superior ride AND better handling:
Front 550lbs coils cut 1/2 coil for lowering
Upper and lower front Poly control arm bushings
custom blueprinted/rebuilt OEM factory steering box
rear Composite 360 lbs spring
Bilstein HD's Front with poly bushings on top
Bilstein Sports rear
factory 1 1/8 inch front bar with all poly bushings
rear 3/4 inch GM style bar with poly bushings
255/45/17 ZR ultra high performance summer only tires
Competition adjustable strut rods with heim joints
Front Spreader bar-Speedirect
My 78 handles almost as good as my 2008 Chrysler 300 3.5L V6 with Bisletins all around, Chrysler front strut brace, Hemi V8 aftermarket front and rear sway bars, and 245/55/18 ZR tires...with a firm not harsh ride..My 300 is stiffer....
FWIW-I would not purchase a kit depending what you have now since both kits have a NON Factory style rear bar (buy a 7/16 GM style rear sway bar and endlinks), and as seen as my suspension above it is best in some cases to mix and match the Bilsteins (fronts HD and rears Sports) for the best ride and handling. For a basic Sport suspension, you would need:
Bilstein HD's Front and Sports in the rear-$400
1 1/8 inch front sway bar-$160
7/16 inch rear GM style only sway bar-$180?
550lb front springs-$90
360 rear composite Spring-$350
Roughly Total-$1,200
I've always felt that poly bushings were the best. they are hard enough to only have minor compression. Where as real race cars use metal on metal heim joints. I just run mine at the lowest point on the cam and for rear shock I use the QA-1 dual adjusts.
VB&P will swap items on the kits. You might ask about a 9/16th smaller rear sway or even 5/8th instead of the listed 3/4. Mine has spring end links front and rear so you can set them to not come into play until you have major wheel vertical movement
I will also check if the kit comes with poly bushing or rubber, it doesn't say on the kits page but it states that the front is lowered 3/4".
In my post #8 above, I do use a bigger rear sway bar 3/4 inch BUT it is a GM STYLE designed rear sway bar and I do have a modified gymkhana suspension on my car in place of the OEM 7/16 inch rear bar. I would recommend a 7/16 inch GM rear bar or maybe the 9/16 inch rear GM bar (BB C3's) but would stay away from the NON factory NON GM rear sway bars. If you are intent on a non factory GM style bar, then I would definitely go smaller AND use adjustable end link bushings that allow more movement of the trailing arm, FWIW....
Today I pulled the wheels and checked my rotors when I found this sticker concealed on the rear suspension. Its hard to say how many years ago this was upgraded.
