New spindle-old flange movement....?
Old Jan 9, 2017 | 08:49 PM
Wee's Avatar
Wee
Default New spindle-old flange movement....?
How much is too much....They say a picture is worth a 1000 words in this case I think a video is better. Maybe all new spindles have this much play...? The old spindle feels pretty good, the new one seems to me to have too much play. What do Ya'll think....?
Brian
Old Jan 9, 2017 | 08:55 PM
tracdogg2's Avatar
tracdogg2
That's the poor quality of an imported spindle.
Old Jan 9, 2017 | 09:36 PM
Wee's Avatar
Wee
I'm sure it was an import at only $100...Will this cause me any issues...? I'll put less than a 1000 miles a year on it....Stock 350 and I don't drive hard.
Anyone else use these imports and seen this kind of movement....?
Brian
Old Jan 9, 2017 | 09:52 PM
rebel542's Avatar
rebel542
Torque it to the recommended setting, 100 ft-lbs I think, and it will be fine. Also get your end play as close to .001 as you can.
Hope this helps.
Old Jan 9, 2017 | 10:09 PM
redvetracr's Avatar
redvetracr
they also say "in life you get what you pay for"
Old Jan 9, 2017 | 10:37 PM
Wee's Avatar
Wee
Touche redvetracr.....good point.
Brian
Old Mar 19, 2017 | 04:55 PM
Dodosmike's Avatar
Dodosmike
I'm going through this issue as well. Except my "noise" developed a bit more than two years after installation of rebuilt trailing arms.
Im going to remove the half shafts and re-torque the spindle nut (100lbs) and check out the movement.
When I drop it in and out of gear is sound exactly like a u joint clicking, but if I crawl under the car and have my beer assistant roll the car back and forth I can SEE the movement between the flange and spindle behind the nut. I chalk it up to crappy spindle during the rebuild, by a forum sponsor no less.
Old Mar 19, 2017 | 05:50 PM
drwet's Avatar
drwet
I agree. I would not be comfortable with that spindle. Not sure what the solution is - don't know if better parts are available, but when you consider the trouble and expense of rebuilding those bearings, I think its worth getting the best parts you can. What is wrong with the old spindles?
Old Mar 19, 2017 | 06:38 PM
CanadaGrant's Avatar
CanadaGrant
Originally Posted by Dodosmike
I'm going through this issue as well. Except my "noise" developed a bit more than two herds after installation of rebuilt trailing arms.
Im going to remove the half shafts and retorque the spindle nut (100lbs) and check out the movement.
When i I drop it in and out of gear is sound exactly like a u joint clicking, but if I crawl under the car and have my beer assistant roll the car back and forth I can SEE the movement between the flange and spindle behind the nut. I chalk it up to crappy spindle during the rebuild
It's interesting that even GM had this same problem with 2005 to 2008 Corvettes and brought out a service bulletin for those years in late 2007. They described it as "a tapping or scraping noise." Their fix was to increase the torque on the nut from 100 to 160 ft lbs as it stated that: "this condition may be due to the torque on the wheel drive shaft nut relaxing over time."
GM service bulletin #07-04-95-001
Old Mar 19, 2017 | 07:32 PM
Dodosmike's Avatar
Dodosmike
Maybe I'll drop a tab of weld on it. Lol
id like to know how wide the grooves are on the OEM spindle vs the "new" one, to see the difference in the casting.
I have an an old spare set of T/A's in storage. 100,000 miles on them. Zero slop in them.
Maybe try my old flanges and slide them on the rebuild spindle and see what kind of movement I get.
Just need to get get the car out of storage. Few more weeks.
Old Mar 19, 2017 | 09:29 PM
TOM B1's Avatar
TOM B1
With that much play just one wheel hop or jack rabbit start and the whole thing will twist off. Its like letting the clutch slip off your foot at every redlight, IT will bust. CHINA CRAP send it back, the last person did and then you got it.
Old Mar 20, 2017 | 05:58 AM
Wee's Avatar
Wee
It's almost completely back together now....I'll report back in a couple of weeks after I get some miles on it....I did use Loctite 609 retaining compound between the flange and spindle.
Brian
Old May 3, 2017 | 10:19 PM
Dodosmike's Avatar
Dodosmike
Wee, any update?
Old May 3, 2017 | 10:49 PM
Wee's Avatar
Wee
No problems so far and no noise that I would expect it to make if it were loose.....That said I haven't put maybe 20 or 30 miles on it since I got everything back together.....Headed to Super Vette Saturday this weekend....That will put another 40 miles on it and I'll report back if I have any issues.
Brian
Old May 4, 2017 | 03:47 PM
Dodosmike's Avatar
Dodosmike
Good to know.
YEs please report back with an update (again).
How much loctite did you put on between the flange and spindle?
Old May 7, 2017 | 07:37 AM
Wee's Avatar
Wee
Put about 40 miles on it yesterday and had no issues at all....After the trip home I shot the bearing housings with a temp gun and both read real close, right at 90 deg.
I put the loctite on both the spindle and flange and coated both pretty well. I'll have to check and see what number I used...It's made for this purpose.
Brian
Old May 14, 2017 | 11:02 PM
Dodosmike's Avatar
Dodosmike
To New spindle-old flange movement....?
Old May 15, 2017 | 11:44 PM
jyounane's Avatar
jyounane
I used Loctite 660. However you need to heat it up to disassemble.
Joe
Old Sep 21, 2017 | 11:30 AM
Dodosmike's Avatar
Dodosmike
Brian
Wee, I'm dropping the half shafts to replace the u-joints and tighten up the spindle nut. Can you comment on the goop you put in the splines and how its holding up?
Old Sep 21, 2017 | 04:53 PM
Wee's Avatar
Wee
I haven't put but maybe another 20 miles on it since the last report. No issues to report, I'll post a pic of the bottle of loctite I used tonight.
Brian
