Location for Oil Temp. Sensor?
Old Jan 14, 2017 | 01:26 PM
Alex66's Avatar
Alex66
Default Location for Oil Temp. Sensor?
Hello,
Where would I install an Oil Temperature Sensor on my 1971 L48 350 Block, and what sensor do i Need to use? I do not want to use the Oil Pan drain screw as the Location. Maybe somebody can sell me one or post a link where i can buy one. I live in Germany, and the Oil Temp sensors there are all metric size threads.
Thank you!!
V/r
Alex
Old Jan 14, 2017 | 02:23 PM
Alex66's Avatar
Alex66
I think I got it... Can I use the Location of the Hex insert above the oil Filter Mount?
Old Jan 14, 2017 | 02:58 PM
'75's Avatar
'75
Yes, that's where the sensor was put for the 81 and 82 models. You should be able to get an oil temp gauge and sensor for an 81 and it will take the place of your clock.
Old Jan 14, 2017 | 06:24 PM
jb78L-82's Avatar
jb78L-82
Correct..that is where I mounted the temp sender on my 78 in 1985! Removed the useless clock and replaced it with the 81/82 oil temp gauge that matches the other gauges perfectly...looks stock. Its been there so long, when I see other C3's with a clock, it strikes me as weird...I did have to relocate my oil pressure sending unit to behind the distributor on the top of the engine though from above the oil filter....
Old Jan 15, 2017 | 03:45 AM
Alex66's Avatar
Alex66
Thank you. Yes, for oil pressure on the old 71' s the pressure line runs too out behind to the side of the Distributor...
Old Jan 15, 2017 | 07:47 AM
Alex66's Avatar
Alex66
What is actually the thread size of this hex insert? I may look for an Adapter so I can use a metric sending unit. A sending unit with a metric thread size i could get everywhere over here, just not US (Inch) thread size one
Old Jan 15, 2017 | 08:21 AM
spikebot 81's Avatar
spikebot 81
The threads will be NPT ( national pipe thread) I think it is 1/4 inch
Old Jan 15, 2017 | 03:25 PM
Alex66's Avatar
Alex66
Can somebody else confirm that the Hex insert above the oil filter is 1/4 NPTF - I did find a VDO oil temp sensor with that size, but would like to be 100% before I order it. It is also available in 1/2 Inch NPTF...
Old Jan 15, 2017 | 03:31 PM
'75's Avatar
'75
Old Jan 15, 2017 | 03:54 PM
Alex66's Avatar
Alex66
OK, I will order 1/4 NPT then... Thank you, Guys!!
Old Feb 27, 2020 | 06:20 AM
FabiChevelle65's Avatar
FabiChevelle65
1st Gear
hi alex66,
bin grad auch dabei eine öltemperaturanzeige einzubauen. War es wirklich ein 1/4NPT Gewinde oder 1/8NPT?
Old Jul 18, 2024 | 10:25 PM
fleonard4's Avatar
fleonard4
3rd Gear
This answered my question I was searching for; if that port could be used for oil temp.
I already have the gauge, and it says it's 740 - 55 Ω, does anyone know where to find this range sending unit with the correct threads for that location?
Old Jul 21, 2024 | 11:37 PM
vettebuyer6369's Avatar
vettebuyer6369
That post was 7.5 years ago.
Try starting a new thread asking your new question.
To Location for Oil Temp. Sensor?
