Ride height on 4 wheels
Old Jan 19, 2017 | 09:58 PM
corvetero's Avatar
corvetero
Default Ride height on 4 wheels
How high are you riding your cars?
I read many times the said " I'm riding the right height" or "1" lower than before" but they almost never talk about the final height.
So what's yours
I'm right now with 29 1/4" on the rear and 28 1/2" on the front.
Looking for 27 1/2" on both axles.
Old Jan 19, 2017 | 10:40 PM
CanadaGrant's Avatar
CanadaGrant
This is right on 27.5" both front and rear.
Old Jan 19, 2017 | 11:06 PM
corvetero's Avatar
corvetero
Absolutely awesome!
Mine is 74 but I guess it would look like very similar.
BTW, what tires? I run 245/60/15
Old Jan 19, 2017 | 11:07 PM
corvetero's Avatar
corvetero
Originally Posted by corvetero
Absolutely awesome!
How did you get that height?
Old Jan 19, 2017 | 11:17 PM
CanadaGrant
Thanks! 255/60/15. I measured from the ground to the top or highest part of the fender opening.
Old Jan 19, 2017 | 11:21 PM
corvetero's Avatar
corvetero
Sorry, I was not clear. What kind of suspension are you using?
Old Jan 19, 2017 | 11:27 PM
CanadaGrant
Ah...gotcha now. That is stock 1969 suspension. GM should have left well enough alone on that one. My wife's 78 looks like a 4x4 when it's beside it.
Old Jan 19, 2017 | 11:30 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
I am also hoping that when my 74 gets back together, I will also be at the 27.5" mark. I am staying with the 225/70/15 tires as they slightly higher in height than the 255/60/15 tire size.
Old Jan 19, 2017 | 11:34 PM
corvetero's Avatar
corvetero
Good for you. You have an amazing car.
Then you will need extra work to bring it down.
Old Jan 20, 2017 | 09:08 AM
MIKE80's Avatar
MIKE80
I have mine at 26.5" front and 27.5" rear. I think the front should be 1" lower than the rear.
Old Jan 20, 2017 | 09:50 AM
Alan 71's Avatar
Alan 71
Hi,
I believe the original ride height ride height for 68-72 cars with F70 tires was 27.9" both front and rear.
Remember the size of the tire has a direct impact on these dimensions, and in addition, it has an impact on the distance seen between the top of the tire and the wheel arch.
Regards,
Alan
Old Feb 2, 2017 | 06:27 PM
corvetero's Avatar
corvetero
Originally Posted by Alan 71
Hi,
Regards,
Alan
You are correct Alan.
225/70/15 diameter is 696mm and 245/60/15 - which is my case- 675mm.
So that means extra 10.5mm (0.41") from the top of tire to the wheel arc.
Any idea about how much the wheel arc drops with 8" bolts and 9 leaf spring? It makes any difference with after market mono leaf?
I'd like to drop at around 2" or 2.5"
Old Feb 2, 2017 | 06:44 PM
Alan 71's Avatar
Alan 71
Hi c,
I 'believe' this to be true….
The car is lowered 1/2 inch for every inch added to the length of the spring bolt.
Perhaps this has to do with the geometry of the rear suspension???
Perhaps someone can verify that?!
Regards,
Alan
Old Feb 2, 2017 | 06:59 PM
theandies's Avatar
theandies
My '71 is 27.5 front and rear. I run 550lb big block springs in the front and Van Steel 330lb composite spring in the back. Can't remember tire size off the top of my head.
Old Feb 3, 2017 | 12:04 AM
corvetero's Avatar
corvetero
So are the front springs original or did you cut a loop?
About the rear. Are you running 6" bolts or 8" ones?
Old Feb 3, 2017 | 12:33 AM
CanadaGrant
Hi c,
Regards,
Alan
Hi Alan, I would think that since the center of the rear spindle is roughly 3/4's of the way back between the front pivot point of the trailing arm and the center of the rear spring bolt hole that you would see a decrease in ride height of roughly 3/4" for every extra inch of spring bolt adjustment.
Old Feb 3, 2017 | 01:03 PM
theandies's Avatar
theandies
BB springs are shorter than SB springs they replaced.
Not sure on the bolts in the back, whatever stock length is. I'll measure them to be sure and look at my tire size.
EDIT - 255/60 R15's 8" bolts
To Ride height on 4 wheels
