77 steering column
Old Jan 22, 2017 | 09:14 PM
brian442's Avatar
brian442
2nd Gear
Default 77 steering column
Hello,i have a 77 all original that was originally equipped with a non tilt/telescopic column & i would like to change this to tilt/telescopic. I have located one in a 76 stingray but have been told they are not interchangeable. Is this true & if so... Why?
Old Jan 22, 2017 | 09:33 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF! Hopefully a Moderator will move this to the C3 area of the forum.
Old Jan 22, 2017 | 10:20 PM
rkj427's Avatar
rkj427
Pro Mechanic
Welcome to the forum!
Try posting this question in the C3 General area for more exposure and opportunity for responses.
Old Jan 22, 2017 | 10:37 PM
Moving this over to the C3 Tech section.
Old Jan 22, 2017 | 10:59 PM
gbvette62's Avatar
gbvette62
Welcome to the Forum!
The 77 column is a one year only part, it does not interchange with any other year. The reason for this is that the 77 was the only year that the windshield wiper switch was incorporated into the column. On all other years, the wiper switch is on the dash.
The 77 columns turn up. They made 49,000 77's, and close to 47,000 of them came with tilt. I use to have a 77 T&T column, that needed to be rebuilt. I'll have to take a look around, I don't recall if I ever sold it or not.
Old Jan 23, 2017 | 09:15 AM
GUSTO14's Avatar
GUSTO14
You might want to contact Forum member Jim Shea (via PM) and ask if he has a solution, he's an expert on these. If there is a solution or a work around Jim will know of it.
https://www.corvetteforum.com/forums/...-jim-shea.html
JIML82@aol.com
Attached is an excellent paper Jim Shea put together on C3 Steering Column's.
Good luck... GUSTO
File Type: doc
Old Jan 23, 2017 | 01:16 PM
brian442's Avatar
brian442
2nd Gear
thank you for the information,please let me know if you have one and i will search else where too. Also i'm looking for plastic "grip" replacement for my e-brake handle if you know of any
To 77 steering column
