79 vette electric door actuator
God Bless
Richard Landaiche
I agree with Gusto, if you are hearing the pop yet the door is not reliably locking/unlocking, clean and lubricate the latch mechanism, lock rod pivot and all rod connections. I also installed the actuators that Willcox sells as my originals had enough drag to make using the key difficult. The replacement actuators are made overseas but work well and have a much nicer rubber boot than the originals. I purchased some metric button head Allen's to fit the supplied nut plates.
I did not have to replace switches but during research found that there are different grades of switches, some absolute junk and some decent replacements. I have also read that some replacements don't have the word "LOCK" on the bezel.
Another common area for trouble is the switch pigtail.
You of course need to remove the door panels but all in all, working in the doors was quite rewarding when finished. Great opportunity to clean, lube and get the power windows working smoothly.
There was a helpful article that I found while searching Corvette Enthusiast magazine titled, Tired of Key Twisting. I don't have the link handy but if you don't find it let me know.
My car is a 79.
As long as you're certain it's attempting to unlock I suspect that you are correct and the actuator needs to be replaced. The passenger side on my '79 is developing the same problem and I'm positive that all of the mechanism is clean and well lubricated.
Replacement isn't difficult. Remove the door panel of course. Then remove the access panel at the bottom of the door (a number of small hex head screws around the perimeter and a bolt in the middle that holds the window motor into position).
The actuator is to the rear of the access hole. You'll be able to feel it. From the factory they're attached with 2? large pop rivets but these may have been replaced with bolts & nuts. Drill out the rivets or remove the bolts. You can then move the actuator to unhook it from the linkage. Install in reverse. If you're using bolts/nuts I prefer "stop nuts"--the kind with plastic at the end that won't loosen with vibration.
My car is a 79.
I bought 2 new switches from Lectric Limited. One switch the pin pushed into the switch the first time I plugged it into THEIR repair harness. They are junk as well.
Thanks Mike. Manually everything works well. Were would you suggest I purchase the motor from?
God Bless
Rich
I will say this....because I have had BRAND NEW A/C Delco ones that were really tight and not good for this application.
Your Corvette has a fiberglass composite door skin. NOT METAL....so...If you buy one...you want to take it by hand and make sure the plunger moves in and out basically effortlessly.
IF it is not free flowing movement....then...even though it may work electrically....but when you go to unlock the door with your door key....NOW...you are having to use excessive force and THUS...this can begin to damage your fiberglass area around your lock cylinder....AND....also begin to put wear marks on your lock cylinder shaft on the backside where the pawl is attached....thus causing its range of movement to change and can cause your alarm system not to work correctly or be REALLY touchy.
DUB
Thanks for replying to this.
AND..I might add...that a person will want to test the door key once everything is lubed up and installed. Because the door key is actually moving the plunger in the pwoer door lock actuator.
DUB
