Help with crate engine choice!
Find a local engine builder and ask him to build your current motor to what you want it to do. I was looking at getting a crate motor, but ended up with a local builder who built me a beast of at big block. And it saved me a lot of money in the process. The only downside to any warranty issues you might run into is with a crate motor, you have to ship the motor back to the builder. And that is not cheap, nor easy to do. If you go with a local guy, chances are you get a warranty, plus you could tow the car across town to him for any repair or set up issues you have, and or just drop by.
That being said, I have lots of good things regarding the crate choices you mentioned.
He said no warranty either, as he couldn't be sure I would be breaking the engine in properly.
For an additional $1K, he'll break in/Dyno the engine (I still install it) and offer a 6 month warranty.
Might want to check around. That is spendy unless it is all new parts inside. Also a dyno run should be less than $1k. Around 1/2 of that is typical unless you are doing a bunch of tuning, etc that is taking a bunch of dyno time. If he is just bolting it up, verifying the timing and running it, $1k is too much. If he has to spend a bunch of time tuning on the dyno with his own build, you should probably check somewhere else also.
I paid the builder $3,500 for the following:
1. Picked up/returned partially disassembled and removed L-82 motor by me from my house
2. Block Prep, Boring, etc and painting of the completed block
3. All new bearings, JE Forged racing pistons/rings (purchased by him and installed)
4. Reconditioned L-82 rods, reconditioned L-82 forged Crank by builder
5. New Harmonic Balancer installed (purchased by builder)
6. Reconditioned OEM flywheel/RAM HDX Clutch kit (purchased by builder)..total assembly balanced by builder
7. Installed new oil pump and pan gasket (both purchased by me prior)
Purchased by me and installed by me..roughly $2,500:
1. AFR 180/64 CC aluminum heads/.015 head gaskets/ARP head bolts
2. New Fuel Pump
3. Howards Roller Cam (.525/110 LSA, 219/225 duration) kit and pushrods (measured by me)
4. New Motor mounts
5. Reused Comp Cams roller tipped 1.52 rockers (less than 25K on them)
6. Reused OEM type distributor
7. Reused Holley 4175 650 CFM Qjet replacement vacuum secondary car
All in about $6K BUT I pretty much have the best parts, did it myself, and know it was done correctly. The L-82 355 now has a roller cam with AFR heads with 10.2:1 and is powerful with tremendous mid range torque which was how the motor was designed to run by builder and myself.
I wanted to keep as much L-82 as possible but with tons more power. Could I have done it cheaper? Absolutely, but there are compromises for the less money and crate engines generally do not use the finest parts but a crate motor overall is a much easier route, less down time, warranty etc. Depends on your goals....
Problem is here in Belgium not a lot of engine builders and the ones that work on small blocks are extremely expensive.
So I am looking at blueprint or ATK for a engine
