Synthetic Oil
Old Jan 26, 2017 | 04:40 PM
rmgny44's Avatar
rmgny44
Default Synthetic Oil
I apologize if this has been beaten to death but any replies or direction to an old thread would be appreciated!
The new Corvette shop I'm using has recommended Redline Synthetic oil in my '72 completely stock small block. Any opinions for or against?
Old Jan 26, 2017 | 04:57 PM
MelWff's Avatar
MelWff
have you looked at the sticky at the top of the C3 forum?
Old Jan 26, 2017 | 05:08 PM
REELAV8R's Avatar
REELAV8R
I would have three concerns.
1) is this a flat tappet engine? If so then make sure you use an oil that has enough zinc in it. At least 1000 PPM for a stockish cam. 1200 or better if a high performance cam with high intensity.
If it'a a roller cam I would not worry about the zinc level, unless again we're talking high intensity cam.
2) I would not use synthetic during the break in period. Conventonal oil with proper zinc levels will ensure a good ring seal for the break in period. A good 1500 ish miles I would say. With a change after cam run in (flat tappet) then a change after a few hundred miles and finally changing to synthetic after the 1500 miles or so.
3) I have used redline in transmissions and it works good there. I have not used it in an engine.
The cost is pretty high in that application @ $50 or so a gallon. If you don't drive it a lot then you won't be able to take advantage of the extended change intervals that synthetic can offer. Which if you use redline drives up the cost of operation quite a bit, which I believe offers no additional benifit over a more affordable synthetic oil.
Old Jan 26, 2017 | 06:57 PM
fishslayer143's Avatar
fishslayer143
I am a firm believer in all things synthetic for automotive lubricants..there is no comparison .
Old Jan 26, 2017 | 08:15 PM
sunflower 1972's Avatar
sunflower 1972
If you really want to use synthetic engine oil, I can recommend Castrol EDGE 5W-50.
It has the appropriate amount of zinc for flat tappet cammed engines. That's what I'm using.
Old Jan 26, 2017 | 10:57 PM
tigertank's Avatar
tigertank
Can you switch to synthetic on a stock motor in an 82 that has about 80000 original miles that's been running regular oil
Old Jan 27, 2017 | 08:37 AM
Big2Bird's Avatar
Big2Bird
Why would you want to?
Old Jan 28, 2017 | 10:21 AM
jb78L-82's Avatar
jb78L-82
That's an easy answer...If you want to give any engine the maximum potential for longevity, a synthetic oil is the only way that will happen. Does not mean conventional oil will not be adequate...of course it is..but for the best potential engine benefit, synthetic is the way to go....
Old Jan 28, 2017 | 10:34 AM
7T1vette's Avatar
7T1vette
With regular oil, engine wear is very slow to occur if you treat the engine right and change oil and filter regularly.
With full synthetic oil, engine wear is almost nonexistent. If an older engine is in reasonably good condition, switching to full synthetic oil can extend useful life considerably [MUCH further than is staying with regular oil].
That's exactly why I switched; I'm just trying to have my engine live as well as it can for as long as it can.
If you find some oil leaks after switching to synthetic, it just means that you have worn seals that are still "adequate" for conventional oil...but not for synthetic oil, which has much smaller molecular size. Your choice would be to go back to regular oil, or to fix the worn seals/gaskets.
To Synthetic Oil
