vbandp dual mount spring problems
Old Jan 31, 2017 | 09:20 AM
c3vetteguy74's Avatar
c3vetteguy74
4th Gear
Default vbandp dual mount spring problems
Has anyone on here had any problems with springs breaking or delaminating on the vbandp dual mount system. I have had two springs break in the center and two begin to delaminate on the ends. I'm really starting to worry about the safety of these springs. I have a total off 850 miles on all four of the springs.
Old Jan 31, 2017 | 10:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you contacted VB&P?
Old Jan 31, 2017 | 10:48 AM
69ttop502's Avatar
69ttop502
Are you running the exhaust close to the spring?
Old Jan 31, 2017 | 11:25 AM
c3vetteguy74
4th Gear
I have contacted them and they have sent replacement spring every time. The exhaust is wrapped with header wrap. Heat isn't the problem.
Old Jan 31, 2017 | 11:33 AM
DaveL82's Avatar
DaveL82
Even with header wrap you can still get heat soak into the spring over time. Can you fit a shield between the spring and the exhaust with a bit of air gap. Later cars with stock fiberglass springs came with a shield for this reason.
Old Jan 31, 2017 | 02:34 PM
c3vetteguy74
4th Gear
Vbandp doesn't seem to think it is a heat problem and the spring itself is a good 2 inches from the exhaust pipe. you can touch it with the engine running and not get burned in that area. I think it is a problem with the adhesive they are using. I can't get them to admit it through.
To vbandp dual mount spring problems
