headers...recomendations please...?
Old Sep 22, 2002 | 02:57 PM
OkeeGuy's Avatar
OkeeGuy
Default headers...recomendations please...?
still a ways off but just doin research...
short or long?
brands?
venders?
other info i should know about?
Old Sep 22, 2002 | 03:43 PM
1979toy's Avatar
1979toy
Default Re: headers...recomendations please...? (SIGNGUY)
Long tube headers or no headers.
Thermo barrier coated headers.
Thicker tubing is better. Remember, in gage sizes smaller is thicker. 14 ga. is thicker than 16 ga.
Old Sep 22, 2002 | 05:09 PM
Ryan77's Avatar
Ryan77
Default Re: headers...recomendations please...? (1979toy)
I'm running the Hedman Elite headers, their 14 gauge and come with a thermal coating. They were 255.99 from Jegs, part number 500-68308. Their specially designed for corvettes from 63-82 so there should be no problems with the fit. My mechanic loved the headers because of how well they fit, and the fact that they didn't hang too low to ground. Underhood and interior temperatures were also greatly reduced after the headers were installed.
[Modified by Ryan77, 4:10 PM 9/22/2002]
Old Sep 22, 2002 | 05:12 PM
scottw's Avatar
scottw
Default Re: headers...recomendations please...? (Ryan77)
I'm putting on Dynomax Cerama-coat Headers, $215.99 from Jegs.
Old Sep 22, 2002 | 05:22 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: headers...recomendations please...? (scottw)
Hooker headers,or Hooker Sidemounts :cool: :cheers:
Old Sep 22, 2002 | 08:37 PM
OkeeGuy's Avatar
OkeeGuy
those look nice...
whata some of you other guys think of these?
will they bolt up without interferance?
[Modified by SIGNGUY, 7:43 PM 9/22/2002]
Old Sep 22, 2002 | 08:49 PM
mg62's Avatar
mg62
those look nice...
I've got 'em, and I'm told they snapped onto the ZZ4 with no troubles.
Old Sep 22, 2002 | 09:04 PM
Petes73's Avatar
Petes73
I'm using Summit's header. Had no problems with the fit. Bolted right up.
Old Sep 25, 2002 | 11:05 PM
69stingray's Avatar
69stingray
According to HOT ROD, for low end torque you should use "stepped" headers. They start at a small diameter tubing and change to a larger diameter. HOT ROD used Hedman Tork-Step when testing GM's 383 crate engine. 1.5" into 1.625". Not sure if Hedamn has a C3 application or if another mfg. does.
http://www.hedman.com/pages/torkstep/torkstep-main.html
Old Sep 26, 2002 | 09:34 AM
Edzred72's Avatar
Edzred72
Thats what I got.. great fit..easy install..good quality for the price.
Eddie
Old Sep 26, 2002 | 11:56 AM
Woodstoc's Avatar
Woodstoc
I went with the Dynomax ceramic coated headers on my 82. The coating was inside and out so rust should never be a problem. Fit was perfect, it was even easy to modify the existing exhaust system to weld up to the header collector adaptor. Came with everything. They look good and even make spark plug access easy. I can get to every plug from the top of the car now vs having to do six from below.
Various places you can get them from, I ordered them through O'Reilleys believe it or not!
Old Sep 26, 2002 | 12:14 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: headers...recomendations please...? (Woodstoc)
I heard Sanderson was among the best.
Old Sep 26, 2002 | 12:42 PM
Mystery Machine's Avatar
Mystery Machine
That's what I have too. I deliberated between these and the "D" shaped ones (I have the ZZ4) from Hedman but opted for the Dynomax because a lot of guys here are running the same combo and had no leaks. They seem to be agood buy, all things considered.
Old Sep 26, 2002 | 12:46 PM
OHSIXX's Avatar
OHSIXX
Default Re: headers...recomendations please...? (Mystery Machine)
Are the Dynomax long tube?
To headers...recomendations please...?
