C3 Temperature Guage Correction
Old Sep 22, 2002 | 06:00 PM
Easy Rider's Avatar
Easy Rider
Default C3 Temperature Guage Correction
I've seen a few messages on this topic, but now I have some hard numbers to deal with.
I put a new radiator core in my '69 350/300 along with a 180 deg. thermostat and a new temperature sender. I also installed all new foam seal around the radiator. I got the temp unit, M112B from ZIP with a new pigtail (wire and clip). When driving, the temp guage has been showing between 212 and 225 deg. F consistently, depending on the outside temperature for some time.
Today, I clamped an A/C type thermometer (metal stem with a button dial) on the side of the top radiator hose next to the thermostst housing. The outside air temperature was in the low 70's. I drove the car for over an hour and it showed a steady reading -- did not move. The guage goes from 210 to 250 with only one hash mark in between, so I'm guessing it was reading about 212-215 deg. F.
I stopped the car with the engine running and popped the hood. The thermometer read 172 deg. F. I continued to drive the car and when I stopped and shut it off, the temp guage read about 205-208 deg. F and the thermometer read 175 deg. F.
Temp Guage Thermometer
at idle 212-215 172
stopped 205-208 175
Can anyone tell me if these temperatures make sense and how to correct the guage reading. I've heard you can put a resistor in-line from the temp sender, but how do you know how many ohms???
Thanks,
Old Sep 22, 2002 | 10:12 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: C3 Temperature Guage Correction (Easy Rider)
I had doudts about what my gauge was reading in the 72. It was always toward the cool side. I then replaced all the gauges with Autometer's. The temp gauge read about 30 degrees hotter than the old factory gauge. The gas station I do a lot of business with had a mechanical gauge which we swapped in for a trial. The mechanical gauge was withinn 5 degrees of the new Autometer electric gauge.
Moral of my story....check calibration of your gauge if possible.
