Replacing side yokes on rear end
Old Sep 22, 2002 | 09:22 PM
467-Ratman's Avatar
467-Ratman
Default Replacing side yokes on rear end
I am planing on changing my stub axles (side yokes) to the heavy duty style and was wondering if they can be removed with taking the half shafts out or do you have to remove the rear end completetly
Old Sep 22, 2002 | 09:55 PM
trw's Avatar
trw
Default Re: Replacing side yokes on rear end (467-Ratman)
Ratman
You have to remove the rear cover to get the clips off. To remove the cover, you have to undo the spring. By then the rears out.
Hope this helps.
Terry
Old Sep 23, 2002 | 01:40 AM
Steve Straus's Avatar
Steve Straus
Default Re: Replacing side yokes on rear end (trw)
Ratman
Hope this helps.
Terry
To remove the cover, the rear has to come off the car. Remember, the cover is what bolts the diff to the rear crossmember.
The short answer is yes, to remove the yokes, you have to remove the rear. It's not as bad of a job as it looks.
To Replacing side yokes on rear end
