Adding Power Steering ...
Old Feb 7, 2017 | 10:35 AM
69Chevelle's Avatar
69Chevelle
Default Adding Power Steering ...
The 71 small block, 4 speed convertible I just purchased doesn't have power steering and I'm considering adding a rack and pinion set-up from Vette Brakes and Products.
https://www.vbandp.com/auto-parts/c2...79-detail.html
Just curious if anyone else has done this or has other suggestions ?
Old Feb 7, 2017 | 10:43 AM
carriljc's Avatar
carriljc
Default I added power steering to my 68...
Bought a brand new stock-type kit and installed it. It has been just fine and works well.
IF I were to do it today - I would go with the Borgesen conversion. Just makes more sense. Take a look at that, or search the forum for Borgesen steering.
Old Feb 7, 2017 | 10:58 AM
OldCarBum's Avatar
OldCarBum
I have power steering on my 73. It was leaking fluid when I bought the car and I found that the prior owner had replaced several components with cheap "made in China" parts. I repaired the leaks and plan to go through the system and swap over to electric steering. There are several threads on this forum that you may want to read that provide good information. I've heard good things about the VBP rack and pinion systems and many swap out their OEM systems to Borgesen.
Old Feb 7, 2017 | 10:04 PM
BLUE1972's Avatar
BLUE1972
I put the Borgeson Power steering in my 71, it is easy and cheep as compared to most others. I love the feel and tracking.
I have since done 3 others and everyone loves the feel.
It also kind of looks like a stock setup, as all the parts are GM.
If I ever want to go back, it will take 1/2 a day to return to original.
Old Feb 8, 2017 | 06:33 AM
terrys6t8roadster's Avatar
terrys6t8roadster
My 6t8 was upgraded to P/S R&P. Way to responsive for daily road use, I'm in the process of moving tie rods to outer holes. The 69 was upgraded to the Borgeson, which is my daily driver, excellent road manners.T
Old Feb 8, 2017 | 07:31 AM
Dynra Rockets's Avatar
Dynra Rockets
I added the 12.5:1 Borgeson a few years ago. Love it. Relatively easy install other than had to unbolt the column in order the get the rag joint right (which is covered in the instructions). Would do again.
Old Feb 9, 2017 | 03:45 PM
FKING1's Avatar
FKING1
Jeep power on my 70 for about 7 yrs.
No cutting or welding.
Very satisfied with it.
To Adding Power Steering ...
