MikeV76Stingray
Old Feb 7, 2017 | 11:25 AM
Mikev76Stingray's Avatar
Mikev76Stingray
3rd Gear
Default MikeV76Stingray
How difficult is it to get to the rear of the radio, or to replace the entire radio in a 1976 Corvette Stingray
Old Feb 7, 2017 | 11:42 AM
ENCSDOUG's Avatar
ENCSDOUG
It's always been easier for me to pull the center gauge cluster. While you are at it, check all your connections and repair as needed.
Old Feb 7, 2017 | 12:01 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
^^^^ What he said.
Old Feb 7, 2017 | 01:28 PM
hugie82's Avatar
hugie82
There's a few hidden screws but once you find them, it comes apart pretty easy. If I remember correctly, there is a screw on each side of the console screwing up into the center panel. The little side panels near the gas pedal and the other side will give you access to the wires and those hidden screws. Usually the OEM radios crap out and sending it out for a rebuild is your only option, unless you are going aftermarket.
To MikeV76Stingray
