front end rebuild....
Kirk
And depending on whose polyurethane control arm bushing you buy...some go in fairly quickly.......others need to have the inner sleeve correctly cut to length to get the proper air gap between teh bushing and the washer....which can be a task at times....and no where near 'easy'. So...it depends.
And for those who may be looking for another option. I have installed the Global West Del-A-Lum bushings for the control arms that have grease fittings so they can be maintained....and from what I have received as feed back form my customers who have them in the car (for years now)...they are very happy with them. And the fluted delrin sleeve can be swapped out if and when needed. Worth taking a look at BUT it is not a simple 1,2,3 install at a home garage in a few hours. It take someone with the ability to do it....and the tools to do it.
Upper control arms
http://www.globalwest.net/1030.html
Lower control arms
http://www.globalwest.net/1055.html
DUB
I used Moog on all items - no issues. The 67 and 71 are driven a lot.
I ordered from Rock Auto and got the MOOG PROBLEM SOLVERS for the upper. It helped in the alignment on the 67 and 71.
Any high quality part will work and last.
I would stay away from front suspension kits....buy the parts separately, preferably Moog, unless you can get a Moog or name brand kit.....many kits have Chinese junk parts today....
Moog for all other parts, but went with a R&P because I needed a new steering box.
Must use lock tight on poly bushings.
Replaced lower ball joints with Moog. That fixed the problem. Think some of the kits are China made.
Having said that, the problem is that a number of these retailers sell what we used to call at Advance Auto Parts, where I worked part-time, for a while, "white box parts".....cheap Chinese made stull, in unmarked, "house brand", white boxes. We sold that crap to mostly the used car dealers, who just needed a part or two to last 4-5000 miles or so, or to some broke-azzed college kid, who was "band-aiding" a car to last two semesters.
If you truly want quality parts, parts that will both work and last, you have to go through the Moog catalog yourself, and get each individual part number, then order them in the quantities you need. It takes a little time, but you'll be sure of what you're getting.
One other caution, as C-3s get older and older, and fewer and further between, replacement parts aren't going to be made in large quantities, anymore. Therefore, it's possible that even if you buy Moog bushings, you may be getting parts that have been sitting on a shelf somewhere, for a period of time, drying out. Be careful, and inspect your parts carefully, before installing them.
Off my soapbox..........
I not to long ago bought 2001 Impala POLICE struts for my 01 Pontiac grand prix...there are no police parts for the GP but lots for the Impala (same W body car). Another example, I bought 01 Impala 12 inch front rotors and impala caliper bracket to upgrade the GP 11 inch rotors for the 12 inch Impala's. I use rockauto for the parts as well as the research for the swap.....
Example for 78 C3 Balljoints:
http://www.rockauto.com/en/catalog/c...ll+joint,10070
Old NOS parts in a box...that can do it. IF installed properly....that is important.Kinda like buying NOS tires with the correct date codes and actually driving the car on the street with 40 year old tires...I would 'say'...is quite insane.....much like old NOS rubber suspension parts. Buy fresh parts...because I really have a hard time thinking that someone can tell if they are original NOS parts or not when installed. Maybe there is someone out there....
DUB
Upper control arms
Lower control arms
[url]http://www.globalwest.net/1055.html[/ur
In all my research on this forum.. on suspensions for our cars Global West is the direction i am going!
