Question for body/paint experts
Old Sep 23, 2002 | 10:49 AM
Neo Fender's Avatar
Neo Fender
Default Question for body/paint experts
My neighbor is having some paint and body work done on his '73 Camaro. I'm going to the same shop today to get an estimate on a repraint of my '79.
My neighbor said that the body shop uses some type of spray on filler that goes on about 1/8" thick. It is then block sanded down as required. Sounds kind of like a spray-on bondo to me. He wasn't sure of the name but it was something like "skis" ???
Is this something that a quality shop would do or is it Earl Schieb work?
Curious.
Old Sep 23, 2002 | 10:57 AM
sb69coupe's Avatar
sb69coupe
Default Re: Question for body/paint experts (Neo Fender)
Was it "SlickSand"? That's the newer version of FeatherFill. Personally, I'd stay away from it. Unless you need lots of leveling and such, I'd go with a modern 2 part epoxy primer/sealer over the bare glass, followed by a urethane 2K primer/surfacer for high build. Block down the surfacer and you'll end up with a nice smooth surface for paint.
I've seen too many problems with urethane paint softening the older polyester and lacquer based surfacers like featherfill and slicksand. If you're shooting a lacquer paintjob they may be OK.
Shannon
Old Sep 23, 2002 | 11:54 AM
fontking1a's Avatar
fontking1a
Hopefully he didn't really say....one-eighth of an inch. If he did....time to find a new painter. I'm sure he really meant a 2 or 3 thousandths of an inch. Nobody sprays .125" worth of material on a car. Your doorhandles would be flush with the paint....yikes.....!!!!!
Old Sep 23, 2002 | 11:57 AM
Neo Fender's Avatar
Neo Fender
Default Re: Question for body/paint experts (fontking1a)
These were my neighbor's words and descriptions, not the painter's.
[Modified by Neo Fender, 9:58 AM 9/23/2002]
Old Sep 23, 2002 | 12:13 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
featherfill sucks.. I'll just put it plain and simple.. its hard to spray, and damn near impossible to sand out. i think its a waste of time. you are much better off with ppg's primer known as K36. you can bury the thing on and it fills really good. but why would you want the primer to fill? thats just for little sand scratches and not body work.
Old Sep 23, 2002 | 04:04 PM
VettePower's Avatar
VettePower
Default Re: Question for body/paint experts (Corzvette69)
K36 is a primer/sealer and not a filler!! is almost damn impossible to sand at all!!! :nono:
Old Sep 23, 2002 | 04:08 PM
Corz's Avatar
Corz
Default Re: Question for body/paint experts (VettePower)
I've sprayed K36 before, i know its not a filler, but you can bury small imperfections in the K36 and will not show up EVER again. i had no problems sanding that primer at all.
Old Sep 23, 2002 | 04:20 PM
VettePower's Avatar
VettePower
K36 is a primer/sealer and not a filler!! is almost damn impossible to sand at all!!! :nono: I've sprayed K36 before, i know its not a filler, but you can bury small imperfections in the K36 and will not show up EVER again. i had no problems sanding that primer at all.
I stand corrected!! I meant DP74 red primer/sealer. The K36 is what I used to fill my car imperfections and it sanded great. :cheers:
Old Sep 23, 2002 | 05:19 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Lars did something like you're describing on a C2, can't remember the name of the stuff he used but he said it works great when a car's body is really wavy and had lots of previous body work performed. Check the archives, that car came out great and the owner was very happy. You could IM the owner and verify how happy he was/is.
Post the thread when you find it.
Old Sep 23, 2002 | 06:27 PM
Roadster71's Avatar
Roadster71
PPG K36 primer/surfacer is the stuff to use. I put 4 coats over a epoxy sealer then wet sanded useing a guide coat. This was then followed by another coat of K36 mixed as a sealer.
Old Sep 23, 2002 | 10:01 PM
Solidlifters
Corzvette hit the nail on the head with featherfill. It's a lazy bodyman's way of quick build up with very bad long term results. It's true that a body can be shot with it, blocked straight, and painted in short order, but it doesn't stay that way in the long haul and you're in a helluva mess if you have to try to feather it to make a repair or much worse if the car is ever to be stripped again. Paint stripper turns it to a chewing gum goo all over the car and there's nothing strong enough to really strip it without attacking the glass. I personally wouldn't use it on a rusty wheelbarrow.
Old Sep 24, 2002 | 12:42 AM
74-Roadster
St. Jude Donor '06
Here's the link to the thread and a quote from the topic:
http://forums.corvetteforum.com/zerothread?id=254088
Quote "The whole thing is really coming out straight, and as soon as he does a little grinding and blending on the work we did today, he'll be ready for a nice thick coat of polyester spraycoat. We'll be applying that right over the top of an epoxy primer coat, and then it's on to blocking and final fill priming." Quote
There was another topic about the polyester but I couldn't find it . . . If Lars used it, it's gotta be good stuff. Check with the shop and see what product it is exactly.
Old Sep 24, 2002 | 01:02 AM
paintdaddy's Avatar
paintdaddy
Default Re: Question for body/paint experts (74-Roadster)
I have used this stuff many times .It is commonly reffered as poly fill .It has gotten a bad rap from people abusing it ,trying to fill small dents and hail damage.As far as corvettes ,I have used it on extremely wavy cars .The way I look at it is ,basically it is thin body filler .Thick primer will crack before thick body filler will crack .Basically what I am saying is ,you have to fix the waves one way or another so why not spray a couple of coats of this first.I always block sand it until see bare glass start to peek through.That tells me that it is almost straight and the poly fill isnt that thick. Then I ll Spray 2 coats of DP primer and 3 coats K36 and block that .After that ,it should be ready . :yesnod: :yesnod:
To Question for body/paint experts
