1969 300/350 pointless ignition
Old Feb 13, 2017 | 08:36 AM
1969Turbo-Fire's Avatar
1969Turbo-Fire
Default 1969 300/350 pointless ignition
Hello from Cold Finland!
I think that i will make pointless ignition conversion..
If i buy ignitor or crane do i have to make any bigger modification? Use original coil and wiring?
I have problems in tach gear axle also, other option is to buy whole new pointless distributor, any suggest to that?
There is some old posts to this topic but there always new products and users, any conversation is welcome.
Old Feb 13, 2017 | 08:54 AM
Dynra Rockets's Avatar
Dynra Rockets
I didn't realize yesterday was that "old".
https://www.corvetteforum.com/forums...-location.html
There are several on the market. I suspect most use the Pertronix. See above thread on eliminating the resistor wire as used in a points system
Old Feb 13, 2017 | 09:13 AM
1969Turbo-Fire
LoL i googled last week this and now remember to made topic.But whole distributors are too what im thinking of...
Old Feb 13, 2017 | 10:18 AM
USAFVeteran's Avatar
USAFVeteran
I installed a MSD tach drive distributor and have had no issues with timing since. I also have a MSD 6AL ignition system too. I'm running 500hp 454 LS-5 now.
Old Feb 13, 2017 | 11:14 AM
Kirk H's Avatar
Kirk H
I installed the pointless ignition by "Lectric "Limited" which makes it impossible to tell it has been modified. It uses the same wire from the coil to distributor and you don't need to add a wire to get a full 12 volts. It runs about $160 and you can get it from a number of Corvette distributors. I also received good support from their company when I had an issue that I created when I was being stupid and they sent me another part no charge. You may want to visit their site and read about it. Good luck.
Kirk
Old Feb 13, 2017 | 05:40 PM
1969Turbo-Fire
MSD is nice but will cost much...when you bought all parts needed.
That Letric limited sounds promising.But also i have that tach gear problem.
Old Feb 13, 2017 | 11:20 PM
Haggisbash's Avatar
Haggisbash
You can rebuild the original distributor including the tach gear if you wish (all the parts are available), that is what I did then added a Pertronix unit and an ignition module from Aldon (they are an English company so would be closer to you to source from) else you can try your luck with one of the aftermarket distributors that are available with a tach drive.
Old Apr 10, 2017 | 02:12 PM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
I'm hijacking the thread so sorry about that!
I'm from Europe also and I'm also making ignition conversion. So far I have leaned toward Breakerless from Lectric Limited because of the ease of instalation. Are you users of that set-up happy with it?
To 1969 300/350 pointless ignition
