Brake Proportion block replacement tips/tricks
Old Feb 14, 2017 | 07:36 AM
kcarlasc's Avatar
kcarlasc
Default Brake Proportion block replacement tips/tricks
Need to replace my brake proportion block as it is leaking from the connection for the rear lines.. not bad but just the same. Anyone have any tricks when swapping the lines from the Master so it does not leak every where. My hands are not that fast to not make a mess...
Old Feb 14, 2017 | 08:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by kcarlasc
...Anyone have any tricks when swapping the lines from the Master so it does not leak every where...
I've used plastic golf tees to plug brake lines.
Old Feb 14, 2017 | 08:07 AM
Alan 71's Avatar
Alan 71
Hi kc,
Are you sure the problem is with the distribution block and not the flare nut on the brake line?
Regards,
Alan
Old Feb 14, 2017 | 08:19 AM
kcarlasc's Avatar
kcarlasc
I am hoping it's just the block.. replacing that back line is a pita...I had replaced all my lines with stainless about 2 years ago or so and did not do the block..
Originally Posted by Alan 71
Hi kc,
Regards,
Alan
Old Feb 14, 2017 | 08:31 AM
Alan 71's Avatar
Alan 71
Hi kc,
The stainless steel lines, while pretty, are sometimes very difficult to achieve a leak free seal with. This is especially true if the lines have been installed with the body on the frame which limits access to working on the connections.
The line itself must be in perfect alignment with the distribution block opening.
When it's not, people use the tightening of the flare nut to 'pull' the line into place. This works to some degree with Bundy steel lines because they're so much more flexible, but not very well at all with stainless lines which are so ridged.
Could that be your problem?
Regards,
Alan
Old Feb 14, 2017 | 08:51 AM
jnb5101's Avatar
jnb5101
Snug all the pipes into the block before mounting the valve to the frame, then tighten all fittings to final torque.
Old Feb 14, 2017 | 09:14 AM
kcarlasc's Avatar
kcarlasc
Hi kc,
Regards,
Alan
It could very well be... just in case the threads are hosed ordered up a new line as well..
Old Feb 14, 2017 | 09:19 AM
jim-81's Avatar
jim-81
These:
https://www.amazon.com/gp/product/B000P9CP3Q/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000P9CP3Q/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
They are awesome.
Old Feb 14, 2017 | 09:26 AM
lvmyvt76's Avatar
lvmyvt76
yeah, when I changed mine over to stainless, I had to really put the "tighten" on the fittings to get them from leaking.
Old Feb 14, 2017 | 10:01 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
use line wrenches only, or you will strip the nut shoulders off.
Old Feb 14, 2017 | 11:47 AM
ignatz's Avatar
ignatz
If you read the (I think) Classic Tubes website on installation of SS lines, they say to repeatedly seat the fitting over and over, tighten a little more each time. Worked for me. And as Alan said, perfect alignment is key to a leak free installation. Do not try to force the alignment. I am on the fence as to whether to use anything to keep the threads from galling. Opinions differ on this. The seal is the flare, so it shouldn't matter as far as leaks go.
Old Feb 14, 2017 | 01:05 PM
Tampa Jerry's Avatar
Tampa Jerry
I used teflon paste from Vette Brakes as a lubricate on the threads. Tighten and back off a few times until the fitting seats. Flair wrenches are a must. No leaks here. Jerry
To Brake Proportion block replacement tips/tricks
