Steering rack option for LS7 conversion
Old Feb 17, 2017 | 12:33 PM
American Heritage's Avatar
American Heritage
Supporting Vendor
Default Steering rack option for LS7 conversion
We are doing a full restoration and LS7 conversion on a 1981 C3.
Need some feedback on rack and pinion steering options.
Any one have any feedback on the rack and pinion conversion kits that are on the market today? Is the steroids setup any good? Who else makes a kit?
Used the search but didn't find much other than the steroid option and no real feedback.
Anyone used an upgraded rack and pinion conversion kit in an LS conversion/swap?
Some Pics:
Frame ready for Por15 treatment:
In the holding spot:
http://www.americanheritageperformance.com/
Old Feb 17, 2017 | 02:09 PM
ddawson's Avatar
ddawson
I have the Steeroids and like the adjustable bump steer.
Had to shim the pump because the steering was really light. Otherwise I love it.
Old Feb 17, 2017 | 04:54 PM
CWerner's Avatar
CWerner
I've got the Flaming River rack on my LS3 conversion (GM LS3 480 HP). I went this route because I liked the frame crossmember support that was part of the design. I've got it tied to a hydro-boost system and they work great.
The tricking part was oil pan clearance. I had maybe 1/16" so I lowered the rack by about 1/4". This was accomplished by shaving 1/4" off the aluminum mounting blocks that bolt to the frame crossmember.
Good luck.
Old Feb 18, 2017 | 07:22 AM
Gordonm's Avatar
Gordonm
You might want to look into the Borgeson setup. I had the Steeroids in mine and clearance as said is very tight with the stock LS3 Vette pan but it did clear. I just think the Borgeson is a cleaner and less hanging down than the Steeroids. Both do work much better than the stock system though.
Old Feb 18, 2017 | 09:09 AM
CWerner's Avatar
CWerner
Gordon has a good point. I've got the borgeson on my C2 and it's real nice. If you preferr finger tip steering then the rack is the answer.
I like them both.
Old Feb 18, 2017 | 09:58 AM
3JsVette's Avatar
3JsVette
For what it's worth that's what Danny Popp is using in his LSx powered C3.
Old Feb 18, 2017 | 10:02 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
There are three company's that I know of making kits, Flaming River, Vette Brakes and Products and Steroids.
I have not installed any of these kits, I did a DIY install of my own build on my car.
Neal
Old Feb 20, 2017 | 04:45 PM
American Heritage
Supporting Vendor
We want to go with Rack and pinion thats for sure...
So it looks like we have to choose between the Steroid Rack or the Flaming River Rack. Are the only differences between the two the mounting brackets?
Is one "beefier" than the others?
Old Feb 20, 2017 | 04:51 PM
drwet's Avatar
drwet
I have the Steeroids setup on my '79 and I like it. Getting the u-joints on the steering shaft is a bit of a challenge, but once you get it, it works well. Huge improvement over the stock setup. I did have a problem with one of the u-joints coming apart after a couple of years and had to replace it. No problem getting the part from Speed Direct.
Old Feb 20, 2017 | 07:19 PM
CWerner's Avatar
CWerner
The FR has a beefier frame structure for sure. I have no opinion on the beef of the rack itself. I'd make the same decision and pick the FR rack if I had the choice.
Here's my build thread
https://www.corvetteforum.com/forums...od-thread.html
Check out post 23, 44, 110. Post 117 shows a Steroids rack with a C3.
To Steering rack option for LS7 conversion
