no spark no fuel pump
Old Feb 17, 2017 | 02:45 PM
stewby's Avatar
stewby
2nd Gear
Default no spark no fuel pump
I have a 1982 corvette cross fire injection running fine then one day it won't start i hear a humming like a back feed coming out of distributer. i replace coil ,module,ignition switch under column still nothing.
I ran a separate ground to distributer and a separate power still no spark or fuel pump operations. totally confused
Old Feb 17, 2017 | 04:48 PM
MelWff's Avatar
MelWff
did you see the responses to your first post? https://www.corvetteforum.com/forums...k-or-fuel.html
can we assume you checked for burnt out fuses?
do you have power at the bat terminal of the distributor?
have you run diagnostics as suggested in this article?
http://chevythunder.com/hei_troubles...ge_2_coil_.htm
