Oil Pump Pick-up
Old Feb 17, 2017 | 08:30 PM
Barrist's Avatar
Barrist
Default Oil Pump Pick-up
I have to admit, I have been away from rebuilds for quite some time.
What are the current thoughts on attaching the pick-up tube ?
My OLD days, was just a couple of brazing spots, no disassembly of the pump.
What are People doing now ? Lock Tite, or something else ?
Thanks,
Bill
Old Feb 17, 2017 | 09:46 PM
mikem350's Avatar
mikem350
Still brazing, IMHO
Old Feb 17, 2017 | 10:53 PM
TimAT's Avatar
TimAT
Last one I did, I put a small bead of Loctite around the tube, checked the clearance off the bottom of the pan, then hit a couple of quick spots with a MIG welder.
Old Feb 18, 2017 | 01:10 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I MIG them all the way around.....the reason is to prevent aeration....not so much for strength......brazing is an option too.....
Jebby
Old Feb 18, 2017 | 06:18 AM
Barrist's Avatar
Barrist
Default Another Idea ?
Thanks for the answers.
Working midnights this week, maybe my brain is fried, but I have another question.
Would there be any drawback to flux and solider ?
My thinking is, copper joints are strong, and maybe a little less heat.
What Ya Think ?
Thanks Again,
Bill
Old Feb 18, 2017 | 08:17 AM
fishslayer143's Avatar
fishslayer143
I have always MIG welded mine , why take the risk? ... Some say its not necessary, but I dispute that.. I have seen two come off , not mine, ..one just pressed in, one with Lock-Tite.. Easy to tell, when one comes off.. first the tapping noise of crank hitting it while it moves around, and second, oil pressure falls rapidly on braking
Old Feb 18, 2017 | 10:16 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Mig welding will not adhere to cast very good, brazing is probobly the best option or I like to weld a tab to the pickup tube and bolt it into place with locktite on the bolt threads.
I've had a pickup tube fall off after being MIG welded on.
Neal
Old Feb 18, 2017 | 01:26 PM
buns's Avatar
buns
These work well:
Old Feb 20, 2017 | 07:11 PM
fishslayer143
Neal
sorry...but you can t call that welded ...never had one fail in 40 years
Old Feb 20, 2017 | 09:46 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Real welding or brazing. I use a Milodon pickup and it has tabs to bolt it to cover bolts. Works great.
Jim.
Old Feb 20, 2017 | 10:08 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
FWIW (if only point out that there are other alternatives), I have a submerged, bottom-feed pump setup. No pick-up tube to fail.
To Oil Pump Pick-up
