I'm restoring my '74 with original Q-jet, stock intake and cowl induction. I noticed someone cut the fuel line years ago for the Holley which is now sold. I'm planning to buy a new fuel line but then thought I may need to cut the pipe to put in an in-line fuel filter. Should I put the filter in front or before the fuel pump? What was the stock setup?
Generally, fuel pumps are not real happy trying to pull fuel thru a filter. No problem pushing thru one. THE stock filter in the Q-Jet would be the way to handle this one.
NEVER run a regular filter before the pump........
The only time this is a consideration is if you are in a jam with a tank full of crap and have to get to a destination......
Never run a fuel filter on the suction side of a mechanical fuel pump - that is a sure way to induce vapor lock and fuel starvation at elevated rpm. Just run the stock, in-carb filter on the Q-Jet - it works quite well. Do not run a second filter on the pressure side of the line. If you decide, for whatever reason, to run an in-line filter between the pump and the carb, remove the stock in-carb filter.
Hey Lars, I am not questioning you by any means. I'm just curious as to why remove the carb. filter. What is the rationale? I would like double protection.
When running a stock mechanical pump, the pressure drop through 2 filters will often cause fuel starvation at wide open throttle - it usually occurs near the top end of 2nd gear. I can't count the number of times I've seen the problem, and it's always solved by removing one of multiple filters installed. 2 filters does not gain you any more protection than 1 filter: you get the filtering protection of whichever filter has the smallest millipore size, but you get the pressure drop associated with two filters. Generally not a good idea, and it gains you nothing.
Lars
In 68 - 69 GM ran the 432 inline filter between the pump and carb and also the carb inlet filter but I think that was just an easy way to plumb the fuel return line.
