73 heater issue
The fan for the heater and A/C is in the engine compartment on the passenger side of the firewall. You should be able to hear and feel the motor running, especially on high. The air is either recirculated through the box from inside or a fresh air door in the passenger fender. The air should come out of the defrost vent on the dash, the upper or lower vents in or under the dash. All of the doors are controlled but vacuum from the console panel. If the hoses are cut, you won't be able to control what goes where but you should still have air flow out of somewhere.
