New Borgeson Box Binding
I installed my new Borgeson box this afternoon at long last. All the existing system was removed, the steering column was shortened, and the new box and rag joint were installed loosely, then everything was tightened up. No hoses have been attached and no fluid is in the system. At the time of video, the pittman arm is not attached to the drag link adapter - the pittman arm is free floating on the steering linkage end.
Here is the state of the steering: when OFF center, the steering seems very responsive - any movement of the wheel transfers through the steering box into the pittman arm. When approaching center turning CLOCKWISE from full left stop, the box appears to gradually start binding. When in this area of travel that binds, I can wiggle the wheel 2-3" in either direction, and that movement doesn't transfer through the box to the pittman arm at all. The steering gets "loose" as the box gets "tight". Then after passing the center of travel, the wheel eases back to normal responsive.
When turning the wheel COUNTERCLOCKWISE, it gets weird. As the wheel travel approaches center, the box starts binding a little more sharply than the other direction, and rather than easing off, it suddenly lets out with a "thunk". When you see this from underneath, you can see the box start to push the worm shaft out into the rag joint, then slip back into place with the thunk.
So that's where I'm at. My questions are:
1. Is this normal?
2. What causes it?
3. Is it an error that I can fix with the box in the car?
4. Whatever else wisdom you guys have to shower on me about this. It was an expensive purchase, and I want to make sure I do it right. Depending on the answers here, I may contact Borgeson about it on Monday, but I wanted to check here first.
Last edited by loquinho; Feb 18, 2017 at 09:12 PM. Reason: Couldn't get the video to work
1. Is this normal?
2. What causes it?
https://youtu.be/KzQkjpnCIKQ
The plan is that I will go onto Borgeson's website and purchase a second box. It will be sent to me with a prepaid return label to send back the faulty box in the original package for the new one. Once received, they will refund the full amount of purchase and any shipping to my card.
I'm really glad I tested it before hooking everything up and putting fluid in the system.
