What should ammeter read with headlights on?
Old Apr 3, 2018 | 10:21 AM
  #41
Vogast's Avatar
Vogast
Originally Posted by Vogast
The short seems permanent now. After hitting the switch, all seems to be shorted. Will run diagnostics as you suggested, thanks!
So after more Easter digging, I realized the left turn signal is not working and it might be causing the short. I checked flashers and bulb, okay. I measured continuity from the bulk connector to a paking light and it’s okay (light blue wire on my 69). That means the signal is not getting through from the turn signal connector?
Old Apr 4, 2018 | 11:06 AM
  #42
Vogast's Avatar
Vogast
Well, I dived under the steering wheel and played a little contortionist with the signal connector, had to bypass it. Now I am getting the turn signal to my parking light again. But the problem did not go away.
With the engine off I hit the turn signal - big movement of ammeter, headlights on, almost to the edge of the meter, hibeam added - the needle is almost lying on the minus side.
I do not want to intice you to this direction but lately I installed a new engine harness and the horn relay contact was bad so I saw a smoke coming from the gauge, so I am suspecting a gauge problem.
I just don't know what else...
EDIT: Problem solved, most likely bad contacts on horn relay
Old Apr 4, 2018 | 07:02 PM
  #43
diehrd's Avatar
diehrd
If the lighting is bright. I recommend a good Sc Fi Book
