Thermostat recommendation
Warm climate always got the best time/power # with the 160 and overall cooler temps. Theories are theories
OP Its all where your car feels happy youll know when you spend time with it. Rest is what it is,opinions.
The T-stat does NOT set the engine and cooling system's operating temperature...unless that system has been over-engineered after the fact. Stat temp only determines the MINIMUM operating temperature of the engine as it warms up. The system will likely continue heating a bit (10-20*F higher) until it completely stabilizes. So, installing a cooler stat only delays the time it takes to reach final stabilized temps.
And I respectfully disagree. From what I've read, learned, been taught, and what I've done since I started working on cars a little while ago, I see different results.
And, I've worked on cars from NC to CA, and now in AZ. I've done this in a few other countries when I was active duty military too. My results have been different than yours.
I do agree with you to one aspect, an engine will find where it's happy, and stay there, as long as the entire cooling system is in good working order. That said, I like to use a 195* t-stat in all my cars. I even run one in my sand car that sees constant on and off throttle runs, and up and down dunes. It gets very warm, but never boils over.
As long as all our cars are working fine to us, I guess it really doesn't matter how we do, huh?
One example is the "record" quarter mile times/trap speeds set at ATCO, and not at Firebird in Phoenix.
The last one was in my 1980 Chevy truck this fall - 305 stock except carb and manifold. Noticed it was running very cold and trans would not lock up. Yep failed open. 180 stat MG.
Hope yours works well for a long time.
Thread a while ago..
Mr GASKET High flow thermostat ?
You didn't specify transmission - manual or auto. If you got an automatic, your radiator is also your transmission cooler. I've never liked a 190-195 in a non EFI vehicle. Their entire system is "closed loop" and the emissions controls are coolant temp dependent. I have a 180 in my '78 L82 automatic. No issues.
a 195 caused my car to spit and burp coolant out of the overflow tank after shut down. and it caused my carb to sizzle after shut down also. it's the temperament of a big block I suppose.
removing a thermostat altogether would cause my temp gauge to barely move off of cold.
a 160 solved all my problems.
you are correct.. some people confuse it with a thermostat in their home where you set temp and it stays there.. Not the case.. the t-stat sets ONLY minimum temp and has no function after that.. temp will vary depending on cooling systems efficiency .. an engine can run 220* with a 160* t-stat 0r a 195* t-stat.. AND..There is no advantage to running a cold engine... COLD INTAKE AIR is the goal to strive for a 195 caused my car to spit and burp coolant out of the overflow tank after shut down. and it caused my carb to sizzle after shut down also. it's the temperament of a big block I suppose.
I just installed a 195 in my brand new LS-5 454. Complete new build, and it takes a bit to get to temp, and so far it stayed at 195. I've been in cold (for Tucson) weather, and warm (90*) weather. It's steady at traveling speeds, sitting at a light, with a lot of close traffic, or light traffic. Maybe I got lucky, again? But I've been getting lucky for over 40 years I guess then....
And you stand a bigger chance of running 220* with a 160* t-stat with a marginal cooling system. And that's a fact. Once the entire cooling system gets above the t-stat temp, it stays open and will not allow the coolant to pause in the radiator long enough to shed any heat at all.
I guess we all have our hard headed ways of how we were taught. I actually did some research, reading, and even tested a few cars I've owned in the past. As long as it works for you.......
T-stats do not "pause" coolant in radiator to shed heat ..nor is there a need to do so. once engine reaches t-stat set temp, it remains open and coolant continues flow depending on engine speed ,unless system can cool engine enough below that temp to close it. .The efficiency of the system and demands on engine determines operating temp
Theres No argument necessary or intended .. I only state my opinion based on more than 4 decades of experience with C3s..... you state your opinion.. Build yours as you see fit, I do not require your compliance or even a response .. However , when you misrepresent things to other less experienced members, who ask questions, I will point it out so they don t make the same mistake without an alternative view .. BTW... NICE PIC !!!
As will I. And you're not the only one here to have over 4 decades of experience with Corvettes. Newsflash, every internal combustion engine with a cooling system works on the same principles.
So go ahead Mr. Last word, and get it now
Had a 1976 L-82, 4-sp
Royal Canadian Navy
To compare a TS in a house to a TS in a car I offer up the following. For home heating systems and associated wall TS's, the walls of our home are the heat exchangers for a loose comparison to car radiators. In winter, the TS is set at 72*F. When temps are below that like 20*F, the heated air in our homes is transferred to the cold air outside through the insulated walls much the same as engine coolant heat is transferred i.e. cooled by the radiator tubes/fins. So, our heating system cuts in and warm air is circulated through the house until the temperature reaches the set point of the TS i.e. 72*F as in this example, and shuts off. This takes say 20 minutes. When the outside temperature drops to -20*F, once again the furnace flashes up and circulates warm air until temperature reaches the set point of 72*F. Only this time it took 30 minutes to reach set point of 72*F. So, car cooling systems are much the same as home heating systems in how they are maintaining set point temperature. It's practical in a home to have an on/off system but impractical for a car as you would drive a couple of miles and need to stop i.e. begins to overheat, and then let it cool to set point temperature like 180*F. Repeat. As I mentioned earlier, to overcome this stop and go for cooling, the TS varies its opening to constantly maintain a temperature of 180*F. The more engine load, the more coolant flows through the TS into the rad and vice versa for less load. For a house, the colder outside, the more heat required to stay cozy. Same thing as a car except the car wants cooler coolant and the house wants warmer air - both systems are controlled by a thermostat. Oh, I forgot to mention today's technology to heat and cool homes - HEAT EXCHANGERS!!!
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I run a 195* thermostat in my big block. My cooling system and timing curve are capable of keeping the coolant temps manageable even on 90+ degree track days.
Once an engine gets hotter than the stat rating, the stat just stays open, and is out of the picture. It's now just how efficient your radiator is in keeping your coolant temps in check, but the stat will only stop the engine coolant from cooling below the stats temp rating.
If you have to slow the pumping of coolant down for it to cool better....the Radiator is too small......
This is why Moroso makes the coolant restrictors.....because most serious drag race cars have Rads that are way too small......the idea is as USAFvet describes....but in competition the idea is to keep the engine as cool as possible for the longest period when running a round.....sometimes the other guy will take forever staging, etc......
Anyhoo.....a 160 is the name of the game in Texas........180 in my home state of Michigan......
I like the Mr. gasket hi-flo with a hole drilled in it.
Jebby
Jebby
