Brake Master Cylinder Seal 1970.
Delco Brake Master Cylinder Seal 1970 Corvette
On the end of the master cylinder sits a round rubber seal 2 1/4" diameter that fits into the recess on the end of the cylinder forming the seal between the master cylinder and the power brake booster. I want to replace as just refurbished the reservoir but having difficulty in finding this part can anyone identify it or know where I can get one?
Kind regards
Paul
Kind regards
Paul
Received 2,878 Likes
Hi Paul,
Take a look at ZIP Products #DB-516.
Is that what you're looking for?
Regards,
Alan
Regards,
Alan
Kind regards
Paul
Having searched a number of forums it seems many have been searching unsucessfully for this part; however this looks very much the part I have been seeking so many thanks I'll follow-up and order, and well done for finding it.
Kind regards
Paul
Paul
Hi c & Paul,
That looks like a pretty nice find!!!!
Regards,
Alan
Regards,
Alan
Best.
Kind regards
Paul
Kind regards
Paul
Kind regards
Paul
Good Luck with the search.
I also have been looking for this part. Including a NAPA store but no one even shows this ring on any of their drawings or listings.
Believe me I don't give up the hunt easily, so if I happen to find them I'll repost here.
Good Luck
Couldn't help myself so I just spoke with Keen Parts and the fella I spoke to let me know that this gasket serves as spacer and no air or fluid is effected by this connection. I understand the desire to keep it original but no harm done if one chooses to fabricate their own gasket. I have again learned something new. Which is a very good thing.
Try this ....
Hopefully it's ok to mention where i found this.
*****If not, then moderator, feel free to delete.****
Googling for it shows Davies Corvette has this for $3.95 and their part number Part #: 534068 ....and they even mention the gm part number right next to it:OEM/GM #: 730392
I always remove and save the seals off of my oil filters as I remove them and throw them in a container. You never know when they might come in handy. You'd be surprised at the different sizes and shapes some of them are. Some are even rectangular instead of round. The fuel filter on my diesel Super Duty uses a big one that is rectangular.
I've found if you need a gasket such as the OP showed, and can't find the exact one, they can often be cut to the length needed and the ends glued together.
Good luck... GUSTO
Good luck... GUSTO
years ago i need a gasket for a oil-cooler adapter
.... since the O-ring part that came with it would not seal. It was just slightly small ....I'd guess "iffy" quality control ...but anyway....
I went to a tranny shop and the guy let me look thru all his "spent" boxes of unused tranny repair parts. There was a multitude of gaskets, seals, rubber parts, gasket parts, and whatnot.
I ended up finding a perfect rubber part. It was even "stepped" so it sealed quite well, I'd guess even better than a properly-sized o-ring would have sealed.
Just an idea for someone looking for seals or gaskets.
Oh, and the guy just gave it to me.
