17" Tire Sizes
Old Mar 19, 2017 | 03:56 PM
The Money Pit's Avatar
The Money Pit
Would any of you gents be willing to share wheel offset info?
I am considering 17's and 255/50, 275/50 size tires, but need to be sure of clearances,....or pitfalls when running 17's. Plan to use 17x9 with 4 1/2 bs on the front, 17x 9 1/2 with 4 1/2 bs on the rear. Need to be sure before ordering these custom wheels.
I see why most go to 18's for tire size options, but I am old school, and prefer taller sidewall tires.
Old Mar 19, 2017 | 08:50 PM
mrvette's Avatar
mrvette
First off, you really need make sure you keep the same wheel center line on any wheels you buy, for instance, I have '89 vette wheels on my '72, and so my car has some mild flares.....but '89 vette wheels are 17/9.5 and so 3/4 inch to inside and outside...
I use 2.5 inch wheel adaptors, from VBP on my car for some 22 years now.....
I run 255/50/17 in front, and they are available Riken Raptor is around.....I had to limit my steering by building out the wheel stops on the lower arms.....
on the rear, I moved the ebrake bracket to behind the rotor, some guys go for up top......at any rate I don't see that 3/4 inch hit anything else, including sway bar.....
The reason for keeping same wheel center line is to prevent loading the suspension, putting extra stresses on rubber/urethane parts.....rear diffy yokes, and ball joints.....
Old Mar 19, 2017 | 08:58 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
245/45/17 front
275/40/18 rear
17x8 18x9
Nitto 555
Jebby
Old Mar 20, 2017 | 01:56 AM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I'm with you on 17"s vs 18"s. Where are you going to buy a 275/50r17? I haven't been able to find any tyres in that size. My wheels are 17x9.5, 5.05" backspace on all 4 corners. On the rear I relocated the handbrake cable to the top of the control arms, shortened the main leaf in the rear spring, and rebent the sway bar, and have heaps of clearance now.
Old Mar 20, 2017 | 08:38 AM
The Money Pit
Originally Posted by Metalhead140
I'm with you on 17"s vs 18"s. Where are you going to buy a 275/50r17? I haven't been able to find any tyres in that size. My wheels are 17x9.5, 5.05" backspace on all 4 corners. Needed a 3mm spacer on the front as my tie rod ends would touch the rim under heavy cornering, and the tyres do rub the chassis rail at full lock. On the rear I relocated the handbrake cable to the top of the control arms, shortened the main leaf in the rear spring, and rebent the sway bar, and have heaps of clearance now.
So 5 inch BS wheels not so much a bolt on. I was thinking 4 1/2 inch BS anyway. In my case, I was thinking 17x9 on the front, 17x9.5 rear, both with 4 1/2 inch BS.
Tires.....I did find M&H drag radials for the rear in 275/50-17. They're 28 inch tall, and section of 11 inches. Should all fit under the fenders if my math is right. I now have 295/55-15 MT drag radials on 9 inch Welds,...they stick out a bit though.
Old Mar 20, 2017 | 10:20 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I got to say all these 17" wheels setups are really nice !
they just look correct fitting to me.
Old Mar 20, 2017 | 06:35 PM
Metalhead140
No, not so much! But not that big a deal either. Most people just remove the swaybar, shorter leaves are available if you don't want to modify your own, as are trailing arms, though it was a very simple and quick modification for anyone who can weld. I think 4.5" backspace would fit fine though.
Ah ok, I'm looking more at performance rubber for handling as well - I run hillclimbs and track days in my car. Let me know if you find anything like that! I suspect the drag radials wouldn't be much good on a track with corners.
Old Mar 23, 2017 | 02:47 AM
PeterC3's Avatar
PeterC3
Any issues with 275/40R17's all around?
My local tire guy recommended them. Now he wants to mount one of the tires to ensure no fit problems, especially in the front wheel well.
Old Mar 23, 2017 | 07:05 AM
mrvette's Avatar
mrvette
I run 255/50/17 in front on '89 vette wheels, same center line because 2.5" thick VBP wheel adapters.....same in rear....the 255 will rub but not much, what you need do is build out the rub block on bottom of the lower control arms, the car will still turn tighter than a C4 at any rate....
275 is a tad large for the front,....IMO....I do have them in rear....
Nitto is only company making 275/50/17 which I run on the rear....same wheel adapters....
Old Mar 23, 2017 | 06:16 PM
Metalhead140
275/40r17 is what I'm currently considering, or maybe 285/40r17. Measured it up, and I'm expecting it will fit ok, but as above, I have some modifications. Keep in mind that a 275/40r17 is 1.4" smaller in diameter than a standard 255/60r15...
Also, what wheel width do you have? I wouldn't run a 275 on an 8" rim.
Old Mar 26, 2017 | 09:06 AM
mrvette's Avatar
mrvette
My '89 vette rims are 17x9.5 on all 4 corners....
2.5" VBP wheel adapters.....
