High voltage issue
Old Mar 9, 2017 | 06:25 PM
Team Malak's Avatar
Team Malak
Cruising
Default High voltage issue
I have a 1974 454 Vette that I just got running after sitting for 25 years. I have had the car running for about 5 months now until last week I ran into an issue. The radio was cutting in and out during high rpms. After checking it out the car was running at 18 plus volts. So I replaced the alternator and still high volts. So I removed the alternator completely and still high volts. So I ran a new positive wire and new ground wires. It is still over 18volts. I replaced the ignition switch and no luck there. I replaced the starter and still high volts. Im at a stand still. I need help on where to go next. Please help.
Old Mar 9, 2017 | 07:54 PM
TimAT's Avatar
TimAT
Have you checked the voltage with a handheld meter? Not the gauge in the car.
Old Mar 9, 2017 | 08:27 PM
Team Malak's Avatar
Team Malak
Cruising
Yes I have and it bounces from 12.5 to a high of 24.6 plus volts. And I checked it at the battery and alternator terminals.
Old Mar 9, 2017 | 09:05 PM
Scottd's Avatar
Scottd
If you removed your alternator and ran the car, Id assume its IMPOSSIBLE to get more than 12 volts as your battery would be your only source of electricity. With the alternator removed, where did you check voltage?
Old Mar 9, 2017 | 09:40 PM
Richard454's Avatar
Richard454
18 volt without an alternator- Then I think your meter is bad. There is no way you'd see that- even if you were running a 16Volt race battery....
Radio cutting in and out- - IF the alternator WAS putting out that high a DC voltage- the radio would play louder....AND your instrument lights will be really bright.
Back in the days when I was in the Car stereo industry- a couple of unscrupulous dealers would run the voltage up on the power supplies to make the radios and amps on display sound better!!!
IF the alternator was putting out AC voltage ( bad diodes) THEN the radio would cut out.
Richard
Old Mar 9, 2017 | 09:54 PM
Team Malak's Avatar
Team Malak
Cruising
I checked the voltage at the battery and at the alternator connections with my multimeter (alternator is not hooked up) and its reading 18volts plus.
The radio is an aftermarket one that has a surge protector in it. It was installed in the car way before I had this issue. I even unplugged the radio completely and I still have a high volts.
Could a power wire be touching the frame cause the volts to up up like this?
Old Mar 9, 2017 | 10:36 PM
Richard454's Avatar
Richard454
NO-
A fully charged battery will be about 12.6 volts
If the car is not running- the alternator will not be charging- there is no way you will see anything more than 12.6V
If the car is running and the alternator is charging you should see 13.7 to 14 volts.
If a "hot" wire was touching the frame - you'd see smoke.
Take the meter to another car and read the voltage- if it says 18V- then you have a bad/inaccurate meter.
Richard
Old Mar 10, 2017 | 03:50 AM
usmilret's Avatar
usmilret
Verify the voltage at the battery while the engine is running. The voltage at the battery should read lower than the volt gauge at the dash.
Old Mar 10, 2017 | 07:15 AM
Team Malak's Avatar
Team Malak
Cruising
I have an HEI distributor installed, could that be leaking voltage into the system? The voltage at the battery is high too (18 plus). And I checked the meter on another car and it was reading fine. I'm going to get my dads meter today to try that one too.
Old Mar 10, 2017 | 08:12 AM
Richard454's Avatar
Richard454
The 74's have an ammeter.
The HEI-to the spark plugs is AC voltage...
Old Mar 10, 2017 | 09:50 AM
Team Malak's Avatar
Team Malak
Cruising
Richard you made me think of something. The voltage is not staying constant. It is jumping all around but likes to stay at 18 for a min. Or so then jumps. Could the coil pack be bleeding off?
Old Mar 10, 2017 | 11:37 AM
MelWff's Avatar
MelWff
what is the voltage reading at the battery with the engine off?
what battery is in the car, manufacturer and model/part#?
Old Mar 10, 2017 | 11:53 AM
Team Malak's Avatar
Team Malak
Cruising
The volts at the battery are 12.42 (engine off) It is a Napa battery # 7524. I had it load test and it was good. Plus the battery is on 2 months old.
Old Mar 10, 2017 | 12:25 PM
MelWff's Avatar
MelWff
with the ignition switch in the ON position but the engine not running
disconnect the two wire plug on the side of the alternator, note the numbers 1 and 2 on the alternator.
connect the red voltmeter lead to the plug at the #1 wire and ground the black voltmeter lead. If you get zero voltage move the wire in the plug to see if there is a partial break at the connector. If you still get zero voltage piece the wire further down with the voltmeter probe and see if you get a reading. If you do the connector is bad and should be replaced. Do the same thing with the #2 wire in the plug.
Old Mar 10, 2017 | 02:52 PM
Team Malak's Avatar
Team Malak
Cruising
Ok update. So I found the issue. My dad told me to put the old points distributor back in the car to (Humor)him. So I did and we are back to a normal running system. So my question is what is the HEI distributor doing then. Why is it bleeding volts into the system.
Old Mar 10, 2017 | 03:27 PM
MelWff's Avatar
MelWff
what did you connect to the BAT connection on the HEI?
did you previously use this HEI in another car without issues?
Old Mar 11, 2017 | 09:15 AM
Team Malak's Avatar
Team Malak
Cruising
I connected straight too the ignition spot (pink wire) on the fuse panel. And this was a brand new unit that I just got. So I'm returning it and for now sticking with the points.
To High voltage issue
