Rear wheel lean??
Old Mar 13, 2017 | 12:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by fishslayer143
...Replace both with the newer replacement ADJUSTABLE Strut rods...
Originally Posted by briankeery
...Spend the dough on a good set of adjustable strut rods...
No disrespect, Gents, but you can get a good rear alignment without aftermarket struts.
Old Mar 13, 2017 | 04:21 PM
theandies's Avatar
theandies
This is true but if the bushings and other things mentioned are worn out, with this rear setup it can be almost impossible to get in and/or keep in.
Old Mar 15, 2017 | 04:28 PM
fishslayer143's Avatar
fishslayer143
True, If and only if the OEM type are new bushings and everything else is tight, and you can get enough adjustment, But RUBBER deteriorates and you are back where you started.. Adjustable struts with Heim joints are forever.. I like that
