Headlight ground strap
Old Mar 13, 2017 | 06:18 PM
hadams's Avatar
hadams
Default Headlight ground strap
Electrical Question for the experts:
Been redoing the interior on the 71 and Just replaced the headlight switch. I repainted the gauge bezels and am concerned that paint on the speedometer bezel in the vicinity of the screw will impact the connection on what is referred to as the ground strap for the switch. This is part of the assembly that attaches to the bezel with a screw. I examined this for a while and am stumped to see the ground path from the bezel to any ground. I don't want to button it up and loose ground for the headlights.
I suppose I will go back and emery cloth the area around the screw but I am still perplexed as to the path.
H
Old Mar 14, 2017 | 08:30 AM
Alan 71's Avatar
Alan 71
Hi H,
In the 71 AIM, UPC 12, Sheet B3, the part is called out as simply 'Strap'.
I've always thought it was there to help stabilize the switch's body as the **** is being pulled and pushed.
I don't see mention of it being a source of ground for the switch.
Do you see that notation somewhere?
Regards,
Alan
Old Mar 14, 2017 | 10:20 AM
hadams's Avatar
hadams
Hi Alan,
Always a pleasure, by the way. You have responded to a good many of my questions and posts in the past, and always provide the most informative, usable and technically correct feedback. Thanks a bunch for that. Great to have experts active on the site, willing to take the time to research, answer and chat.
Anyway, I got the idea planted when I ordered the new switch. The dimmer coil had disintegrated in the original and I could not repair it on the bench. When I ordered the switch, I noticed this at Corvette Central: http://www.parts123.com/corvettecent...50g&ukey=27778
Item number 593114 at Corvette Central isreferred to as "Headlight Switch Ground Strap. I had assumed same, (that it was for stability), but became concerned after seeing the item on-line. I don't have an Assembly Installation Manual. Where can you get the? Amazon?
Best,
Howard
Old Mar 14, 2017 | 11:18 AM
Alan 71's Avatar
Alan 71
Hello Howard,
Yes the 71 AIM is available from a variety of sources.
The larger vendors like Paragon Reproductions, ZIP Products, and Corvette Central carry them.
I also see it on e-bay and I'd think amazon too.
Regards,
Alan
Old Mar 14, 2017 | 12:39 PM
Peterbuilt's Avatar
Peterbuilt
The strap supplies a ground from the headlight switch.
When you turn the headlight K *** counter clockwise it connects to that strap so that the courtesy lights turn on.
Old Mar 14, 2017 | 02:12 PM
Peterbuilt's Avatar
Peterbuilt
Originally Posted by hadams
Electrical I examined this for a while and am stumped to see the ground path from the bezel to any ground.
Here's a picture.
The BLACK wire is the ground for the tach & speedo, the other end connects to the 'A' pillar.
Old Mar 14, 2017 | 02:13 PM
Peterbuilt's Avatar
Peterbuilt
Here's how the vacuum hoses connect.
Old Mar 14, 2017 | 02:58 PM
Alan 71's Avatar
Alan 71
Hi Pb,
I thought the fastener for that strap connected to a plastic part… the speedometer bezel, not to speedometer case which I agree, is grounded.
So I couldn't understand where the ground was made?
Regards,
Alan
Old Mar 14, 2017 | 08:33 PM
Peterbuilt's Avatar
Peterbuilt
Originally Posted by Alan 71
Hi Pb,
Regards,
Alan
Hi Alan,
It's been many years since I've been near the back of my dash so I can not say with 100% certainty what the screw goes into but it wouldn't be a ground strap if it went into plastic.
Do you have a photo of that area? I don't.
Besides:
Old Mar 15, 2017 | 08:42 AM
Alan 71's Avatar
Alan 71
Hi Pb,
What do you think?
Regards,
Alan
Old Mar 15, 2017 | 11:13 AM
Peterbuilt's Avatar
Peterbuilt
We need a picture of the speedo bezel screw hole.
Is the plastic part that the screw goes in sleeved (with metal) and connected to the speedo bezel?
It has to ground somehow or the courtesy lights will not go on.
The white wire supplies a ground to the courtesy lights.
The white wire only plays a part in the system when you rotate the k *** fully left.
That pushes the headlight switches TAB into the bracket that holds the headlamp switch and supplies a ground.
Old Mar 15, 2017 | 11:32 AM
Alan 71's Avatar
Alan 71
Hi Pb,
If the 'deep' bezel is metal (I'm not sure?) than it WOULD be the path for the ground…. so it must be metal.
Regards,
Alan
Old Mar 15, 2017 | 04:45 PM
theandies's Avatar
theandies
I know my headlight switch has a metal bracket where the switch goes through the dash pad. It's then attached to the back of the speedo. Not sure it's a ground or not. I think all it does is give the dash pad some backing because that is where the nut that holds the switch in tightens down.
I'm sure Alan has a picture. lol
Old Mar 15, 2017 | 05:21 PM
DEEPSEA70's Avatar
DEEPSEA70
Here is an "exploded" view.
Kind of hard to tell, and remember its been so long.
Old Mar 15, 2017 | 05:47 PM
Alan 71's Avatar
Alan 71
Hi,
Thanks D70
So the bezel would need to be metal (it well may be) in order for the ground connection to be completed.
Regards,
Alan
Also, notice the blue stripe hose is on the forward nipple… not the way it's shown in the 71 AIM.
Old Mar 15, 2017 | 06:43 PM
bazza77's Avatar
bazza77
Old Mar 15, 2017 | 06:51 PM
bazza77's Avatar
bazza77
Hi Pb,
Regards,
Alan
yes its cast pot alloy , very fragile .
post #6 by peterbuilt gives the ground path off the dash panel to frame. Also there is another ground wire that comes off the headlight support bar
To Headlight ground strap
