Need help with diagnostics on an '82 C.E., please.
Old Sep 24, 2002 | 11:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Need help with diagnostics on an '82 C.E., please.
A friend has a very nice C.E. which has started throwing a code (SES flashes) on the highway.
Though I suspect the EGR system I was going to pull the codes to verify. I own an '88 Vette and am unfamiliar with components on an '82; I couldn't find the ALCL to hook up my scanner. Can anyone please describe it's location.
Assuming it is an EGR code, I also need help locating the EGR Temp Sw. The EGR valve and solenoid are easy to spot but I haven't yet found the Temp sw. I could realy use some help with locating it also.
Thanks much for any help.
Old Sep 25, 2002 | 12:09 AM
tankman's Avatar
tankman
Default Re: Need help with diagnostics on an '82 C.E., please. (65Z01)
I'm sure someone with more knowledge than this shadetree will join in,but for starters thealcl is under the ashtray.just pull it up and you'll see it (I think) :yesnod:
Old Sep 25, 2002 | 12:19 AM
65Z01's Avatar
65Z01
Default Re: Need help with diagnostics on an '82 C.E., please. (tankman)
Under the ashtray :crazy:, well of course, now why wouldn't I look there, silly me.
Thanks much.
Old Sep 25, 2002 | 08:09 AM
BLU 4ME's Avatar
BLU 4ME
The plug in module is under the ashtray. I could'nt find a [ses] code in my book.
Old Sep 25, 2002 | 02:04 PM
65Z01's Avatar
65Z01
Default Re: Need help with diagnostics on an '82 C.E., please. (7782vette)
Thanks for the responses.
I have an AutoXray that I'll to plug into his ALCL to verify the code.
Does anyone know where the EGR Temp. Sw is located.
BTW 7782vette, what code were you getting that you couldn't find?
[Modified by 65Z01, 12:06 PM 9/25/2002]
To Need help with diagnostics on an '82 C.E., please.
